Cisco ASA 5500 Series adaptive security appliances are purpose-built solutions that combine best-of-breed security and VPN services with the innovative Cisco Adaptive Identification and Mitigation (AIM) architecture. Designed as a core component of the Cisco Self-Defending Network, the Cisco ASA 5500 Series provides proactive threat defense that stops attacks before they spread through the network, controls network activity and application traffic, and delivers flexible VPN connectivity. The result is a powerful multifunction network security appliance family that provides the security breadth and depth for protecting home office, branch office, small and medium-sized business, and enterprise networks while reducing the overall deployment and operations costs and complexities associated with providing this new level of security.
- Cisco ASA 5505 Firewall Edition Bundle - security appliance
- Security appliance
- Licence Qty
- 50 users
- Form Factor
- External
- RAM
- 512 MB (installed) / 512 MB (max)
- Flash Memory
- 128 MB
- Ports Qty
- 8
- Data Link Protocol
- Ethernet, Fast Ethernet
- Performance
- Firewall throughput: 150 Mbps , VPN throughput: 100 Mbps
- Capacity
- IPSec VPN peers: 10 , SSL VPN peers: 2 , Concurrent sessions: 10000
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 20 cm x 17.4 cm x 4.4 cm
- 1.8 kg
- Installed Modules Qty (Max)
- 0 (1)
- 20 cm
- 17.4 cm
- 4.4 cm
- 1.8 kg
Processor / Memory / Storage
- RAM
- 512 MB (512 MB max) DDR SDRAM DIMM 184-PIN
- Flash Memory
- 128 MB
- Form Factor
- External
- Ports Qty
- 8
- Connectivity Technology
- Wired
- IPSec
- Performance
- Capacity
- Firewall protection, DMZ port, power over Ethernet (PoE), VPN support, VLAN support, wall mountable
- Encryption Algorithm
- DES, Triple DES, AES, SSL
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 6 x 100Base-TX - RJ-45 , 2 x 100Base-TX (PoE) - RJ-45 , 3 x USB 2.0 - Type A , 1 x management - RJ-45
- Rack Mounting Kit
- Optional
- FCC Class B certified, VCCI Class B ITE, CISPR 22 Class B, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, FCC Part 15
- PoE
- Power Device
- External power adapter
- Voltage Required
- 0 °C
- 40 °C
- 5 - 95%
