Product
Cisco Antenna/Multi-Bd OutDoor Omni-Direction
Quicklinx: B038WS00 Mfr#: 3G-ANTM-OUT-OM=
It is designed for 3G HWIC applications in the 800/850/900/1800/1900/2100 MHz frequency bands. The antenna has a nominal gain of +2 dBi for 800/850/900 MHz bands and +4 dBi for 1800/1900/2100 MHz bands. It is designed for installation on a mast or exterior wall.
Cisco 3G Omnidirectional Outdoor Antenna - antenna
Antenna
3.2 cm 40.6 cm
Product Material
Plastic
Aerial Placing / Mounting
Outdoor, wall-mountable, pole mount
Frequency Range
806 - 960 MHz, 1.71 - 2.17 GHz
Gain
2 dBi (for 806 - 960 MHz), 4 dBi (for 1710 to 2170 MHz)
Directivity
Omni-directional
Antenna
Product Material
Plastic
3.2 cm
40.6 cm
Aerial
Frequency Range
Gain
Directivity
Omni-directional
Voltage Standing Wave Ratio (VSWR)
2.5:1
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x TNC male
Mounting Kit
Included
-40 °C
85 °C
