Every wireless Local Area Network (LAN) deployment is different. When engineering an in-building solution, varying facility sizes, construction materials, and interior divisions raise a host of transmission and multipath considerations. When implementing a building-to-building solution, distance, physical obstructions between facilities, and number of transmission points must be taken into account.
Cisco is committed to providing not only the best access points, client adapters, and bridges in the industry-it is also committed to providing a complete solution for any wireless LAN deployment. That's why Cisco has the widest range of antennas, cable, and accessories available from any wireless manufacturer.
Cisco offers a complete range of 2.4 GHz antennas for client adapter, access point, and bridge equipment that enable a customized wireless solution for almost any installation.
This antenna is intended for use with access points or bridges.
- Cisco Aironet Antenna Kit Yagi - network adapter antenna
- Product Type
- Network adapter antenna
- Length
- 18.4 cm
- 0.2 kg
- Gain
- 10 dBi
- Directivity
- Directional
- Designed For
- Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
- Product Type
- Length
- 18.4 cm
- 0.2 kg
Aerial
- Gain
- 10 dBi
- Directivity
- Directional
Cabling & Wiring
- Connector Provided
- 1 x RP-TNC
- Designed For
- Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
