The AIR-ANT2485P-R is a wall mount indoor/outdoor antenna with a RP-TNC connector-Designed for use with any radio that features a RP-TNC connector. For use in the 2400-2500 MHz frequency band. The plenum rated pigtail cable is 36" long.
- Cisco Aironet Patch - antenna
- Product Type
- Antenna
- 13.5 cm x 1.9 cm x 13.5 cm
- Aerial Placing / Mounting
- Wall-mountable
- Gain
- 8.5 dBi
- Directivity
- Directional
- Designed For
- Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
- Product Type
- Antenna
- 13.5 cm
- 1.9 cm
- 13.5 cm
Aerial
- Wall-mountable
- Gain
- 8.5 dBi
- Directivity
- Directional
Cabling & Wiring
- Connector Provided
- 1 x RP-TNC
- Designed For
- Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
