Product
Cisco Aironet 702i Standalone Radio Access Point 802.11a/b/g/n
Quicklinx: BQMVWS00 Mfr#: AIR-SAP702I-E-K9
  • IEEE 802.11n
The Cisco Aironet 700 series offers a compact access point for value-minded customers looking to modernize their networks to handle the increasingly complex wireless access demands.
With 802.11n dual-radio 2 x 2 multiple-input multiple-output (MIMO) technology providing at least six times the throughput of existing 802.11 a/g networks, the Cisco Aironet 700 series offers the performance advantage of 802.11n quality at a competitive price.
As part of the Cisco unified wireless network, the 700 series access point provides low total cost of ownership and investment protection by integrating seamlessly with the existing network.
Cisco Aironet 702i Standalone - radio access point
Radio access point
External
RAM
128 MB
Flash Memory
128 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
17.76 cm x 17.76 cm x 5.04 cm
480 g
Radio access point
17.76 cm
17.76 cm
5.04 cm
480 g
Processor / Memory / Storage
RAM
128 MB
Flash Memory
128 MB
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Power over Ethernet (PoE), DFS support, Wi-Fi Multimedia (WMM) support, 2T2R MIMO technology, Maximum Ratio Combining (MRC)
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, ICES-003, EN 300.328, EN 301.489.17, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 300.489.1, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, ARIB STD-T33, CAN/CSA C22.2 No. 60950-1, EMI, SRRC
PoE
9.5 Watt
Limited warranty - lifetime
10 - 90% (non-condensing)
BQMV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
BQMV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.62
BQMV C2G 2m Cat6a Shielded Patch - Blue In Stock £7.24
