Cisco Aironet 3702i Controller-based Radio Access Point
Quicklinx: 9JK7WS00 Mfr#: AIR-CAP3702I-E-K9
Type: Radio access point
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Compatibility: PC
  • IEEE 802.11n
£965.18 ex VAT
£1,158.21 inc VAT
With the industry's only enterprise class 4 x 4 MIMO, three-spatial-stream access points that support the IEEE's 802.11ac specification, the Cisco Aironet 3700 series delivers industry-leading performance and a High Density Experience (HD Experience) for both the enterprise and service provider markets. The Aironet 3700 series extends support to Wi-Fi clients, such as smartphones, tablets, and high-performance laptops that have integrating 802.11ac support.
In its first implementation, 802.11ac wave 1 provides a rate of up to 1.3 Gbps, roughly triple the rates offered by today's high-end 802.11n access points. This provides the necessary foundation for enterprise and service provider networks alike to stay ahead of the performance and bandwidth expectations and needs of their wireless users.
Due to its convenience, wireless access is increasingly the preferred form of network connectivity for corporate users. Along with this shift, there is an expectation that wireless should not slow down users' day-to-day work, but should enable a high-performance experience while allowing users to move freely around the corporate environment.
  • High Density Experience (HD Experience)
    Building on the Cisco Aironet heritage of RF excellence, the 3700 series utilizes a purpose-built chipset with the best-in-class RF architecture. This chipset provides a High Density Experience for enterprise network designed for mission critical, high performance applications.
  • Scalability
    The Cisco Aironet 3700 series is a component of the Cisco unified wireless network, which can scale to as many as 18,000 access points with full layer 3 mobility across central or remote locations on the enterprise campus, in branch offices, and at remote sites. The Cisco unified wireless network is the industry's most flexible, resilient, and scalable architecture, delivering highly secure access to mobility services and applications and offering the lowest total cost of ownership and investment protection by integrating smoothly with the existing wired network.
Cisco Aironet 3702i Controller-based - radio access point
Radio access point
External - indoor
RAM
MB 512
Flash Memory
64 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
22.1 cm x 22.1 cm x 5.4 cm
1.13 kg
Radio access point
Ruggedized Design
Indoor
22.1 cm
22.1 cm
5.4 cm
1.13 kg
Processor / Memory / Storage
RAM
512 MB
Flash Memory
64 MB
External
Wireless
Data Transfer Rate
1.3 Gbps
Line Coding Format
CCK
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
Auto-sensing per device, Wi-Fi Multimedia (WMM) support, CleanAir technology, Maximum Ratio Combining (MRC), 4T4R MIMO technology, ClientLink 3.0 technology
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, ICES-003, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, EMI, EN 300 328, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE+
Limited warranty - lifetime
10 - 90% (non-condensing)
9JK7 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
9JK7 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.69
9JK7 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.20
Speed: 1.3Gbps
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Cisco
Price Range Ex VAT: 750 - 1000
