Cisco Aironet 3500 series access point with Cisco CleanAir technology is the 802.11n access points to create a self-healing, self-optimizing wireless network. CleanAir technology is a system wide feature of the Cisco Unified Wireless Network that improves air quality by detecting RF interference that other systems can't recognize, identifying the source, locating it on a map, and then making automatic adjustments to optimize wireless coverage. This access point provides the highest-performance 802.11n connectivity for mission-critical mobility. By intelligently avoiding interference, the 3500 series offers performance protection for 802.11n networks to help ensure reliable application delivery.
RF excellence
Building on the Cisco Aironet heritage of RF excellence, the 3500 series delivers industry-leading performance for secure and reliable wireless connections. Enterprise-class silicon and optimized radios deliver a robust mobility experience using Cisco M-Drive technology. -
Scalability
The Cisco Aironet 3500 series is a component of the Cisco Unified Wireless Network, which can scale up to 18,000 access points with full Layer 3 mobility across central or remote locations on the enterprise campus, in branch offices, and at remote sites. The Cisco Unified Wireless Network is the industry's most flexible, resilient, and scalable architecture, delivering secure access to mobility services and applications and offering the lowest total cost of ownership and investment protection by integrating seamlessly with the existing wired network.
- Cisco Aironet 3502P - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power
- AC 120/230 V (50/60 Hz)
- 22.1 cm x 22.1 cm x 4.7 cm
- 0.86 kg
- 22.1 cm
- 22.1 cm
- 4.7 cm
- 0.86 kg
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.3af, IEEE 802.11n
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 6 x aerial
- Mounting Kit
- Included
- VCCI Class B ITE, EN55022 Class B, ICES-003 Class B, FCC Part 15.247, RSS-210, RSS-102, UL 2043, EN55024 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, FCC Part 15.407, TELEC, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1
- Power Device
- External power adapter
- Voltage Required
- -20 °C
- 55 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
