Cisco Aironet 3500 series access points with Cisco CleanAir technology are the industry's first 802.11n access points to create a self-healing, self-optimizing wireless network. CleanAir technology is a system wide feature of the Cisco Unified Wireless Network that improves air quality by detecting RF interference that other systems can't recognize, identifying the source, locating it on a map, and then making automatic adjustments to optimize wireless coverage. These innovative access points provide the highest-performance 802.11n connectivity for mission-critical mobility. By intelligently avoiding interference, the 3500 series offers performance protection for 802.11n networks to help ensure reliable application delivery.
- Cisco Aironet 3502i - radio access point
- Radio access point
- Form Factor
- External
- Localisation
- Belgium, Bahrain, Saudi Arabia, Bulgaria, Czech Republic, Estonia, Lithuania, Vietnam, Iceland, Romania, Thailand, Puerto Rico, Luxembourg, Hungary, Cyprus, Uruguay, Liechtenstein, Gibraltar, Malta, Monaco, Bosnia, Slovakia, Slovenia, Latvia, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Ireland, Serbia, Montenegro
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 22.1 cm x 22.1 cm x 4.7 cm
- 1.04 kg
- Limited lifetime warranty
- 22.1 cm
- 22.1 cm
- 4.7 cm
- 1.04 kg
- Localisation
Processor / Memory / Storage
- RAM
- 128 MB
- Flash Memory
- 32 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Line Coding Format
- CCK
- Spread Spectrum Method
- OFDM
- Status Indicators
- Status
- Auto-sensing per device, power over Ethernet (PoE), MIMO technology, Wi-Fi Multimedia (WMM) support, CleanAir technology, Cisco M-Drive technology
- Encryption Algorithm
- AES, TLS, PEAP, TTLS, TKIP
- Authentication Method
- MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Gain Level
- 4 dBi
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- Mounting Kit
- Included
- VCCI, ICES-003, EN 300.328, EN 301.489.1, EN 301.489.17, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, ARIB STD-T33, CSA C22.2 No. 60950-1
- PoE
- Power Device
- External power adapter
- Voltage Required
- Limited warranty - lifetime , Limited warranty - replacement - 10 days
- 0 °C
- 40 °C
- 10 - 90%
