Your basket is empty
Cisco Aironet 2602e Controller-based Radio Access Point
Quicklinx: 96YKWS00 Mfr#: AIR-CAP2602E-E-K9
  • IEEE 802.11n
The Cisco Aironet 2600 series Access Point delivers the most advanced features in its class - with great performance, functionality, and reliability at a great price. The 802.11n based Aironet 2600 series includes 3x4 MIMO, with three spatial streams, plus Cisco CleanAir, ClientLink 2.0, and VideoStream technologies, to help ensure an interference-free, high-speed wireless application experience. Second only to the Cisco Aironet 3600 Series in performance and features, the Aironet 2600 Series sets the new standard for enterprise wireless technology.
Designed with rapidly evolving mobility needs in mind, the Aironet 2600 series access point is packed with more Bring Your Own Device (BYOD)-enhancing functionality than any other access point at its price point. The Cisco Aironet 2600 series sustains reliable connections at higher speeds farther from the access point than competing solutions resulting in more availability of 450 Mbps data rates. Optimized for consumer devices, the Aironet 2600 series accelerates client connections and consumes less mobile device battery power than competing solutions.
Cisco Aironet 2602e Controller-based - radio access point
Radio access point
External
RAM
256 MB
Flash Memory
32 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
22.1 cm x 22.1 cm x 5.4 cm
1.22 kg
Radio access point
22.1 cm
22.1 cm
5.4 cm
1.22 kg
Processor / Memory / Storage
RAM
256 MB
Flash Memory
32 MB
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
DFS support, MIMO technology, Wi-Fi Multimedia (WMM) support, CleanAir technology, Maximum Ratio Combining (MRC), ClientLink 2.0 technology
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, ICES-003, EN 300.328, FCC Part 15.247, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 300.489.1, EN 301.893, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, CAN/CSA C22.2 No. 60950-1, EMI
Limited warranty - advance parts replacement - lifetime - response time: 10 days
-20 °C
55 °C
10 - 90% (non-condensing)
96YK C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.09
96YK C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.60
96YK C2G 2m Cat6a Shielded Patch - Blue In Stock £6.53
96YK C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.38
