Cisco Aironet 1852I - Radio access point - 802.11ac (draft 5.0)
Quicklinx: CFBJWS00 Mfr#: AIR-AP1852I-E-K9
Type: Radio access point
Connectivity: Wireless
Speed: 1.7Gbps
Protocol: IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11b + 1 more
Compatibility: PC
  • IEEE 802.11n
£783.53 ex VAT
£940.23 inc VAT
Ideal for small and medium-sized networks, the Cisco Aironet 1850 Series delivers industry-leading performance for enterprise and service provider markets via enterprise-class 4x4 MIMO, four-spatial-stream access points that support the IEEE's 802.11ac Wave 2 specification.
  • MU-MIMO
    802.11ac Wave 2 with 4x4 Multiple-Input Multiple-Output (MIMO) technology with four spatial streams when operating in single-user MIMO mode and three spatial streams while operating in multi-user MIMO mode, offering 1.7 Gbps rates for more capacity and reliability than competing access points
  • APPLICATION VISIBILITY AND CONTROL
    Network Based Application Recognition (NBAR) deep-packet inspection technology provides application-aware control on a wireless network and enhances manageability and productivity. It also extends Cisco's Application Visibility and Control (AVC) as an end-to-end solution, which gives a complete visibility of applications in the network and allows the administrator to take some action on the same.
  • RADIO RESOURCE MANAGEMENT
    Cisco's Radio Resource Management (abbreviated RRM) allows Cisco's Unified WLAN Architecture to continuously analyse the existing RF environments, automatically adjusting each AP's power and channel configurations to help mitigate things such as co-channel interference and signal coverage problems. RRM reduces the need to perform exhaustive site surveys, increases system capacity and provides automated self-healing functionality to compensate for RF dead zones and AP failures
  • SECURITY
    Securing the Device: Cisco Umbrella (OpenDNS), Identity PSK (iPSK), IP and DNS ACLs. Securing the Air: Spectrum Intelligence, Wireless Intrusion Detection (WIDS). Securing the Network: 802.1x on AP, AAA profiling and policy
  • PEACE OF MIND
    Limited lifetime hardware warranty
Cisco Aironet 1852I - radio access point - Wi-Fi 5
Radio access point
External - indoor
Belgium, Bahrain, Lebanon, Oman, Saudi Arabia, United Arab Emirates, Bulgaria, Czech Republic, Estonia, Lithuania, South Africa, Iceland, Romania, Sri Lanka, Luxembourg, Hungary, Cyprus, Iraq, Ghana, Kenya, Nigeria, Liechtenstein, Gibraltar, Malta, Monaco, Croatia, Slovakia, Slovenia, Latvia, Libya, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Turkey, Ireland, Serbia, Montenegro, Bosnia and Herzegovina
RAM
1 GB
Flash Memory
256 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 5.0)
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
AC 120/230 V (50 - 60 Hz)
21.08 cm x 21.08 cm x 50.8 cm
1.41 kg
Radio access point
Ruggedized Design
Indoor
21.08 cm
21.08 cm
50.8 cm
1.41 kg
Processor / Memory / Storage
RAM
1 GB
Flash Memory
256 MB
External
Wireless
Data Transfer Rate
1.7 Gbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status
DFS support, Wi-Fi Multimedia (WMM) support, Link Aggregation Control Protocol (LACP), Maximum Ratio Combining (MRC), 4T4R MIMO technology, 802.1x authentication, radio resource management (RRM), cyclic shift diversity (CSD), MU-MIMO technology, beamforming technology
Encryption Algorithm
AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2
Authentication Method
MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11h, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac (draft 5.0)
Aerial
Antenna
Internal
Directivity
Omni-directional
Gain Level
5 dBi
1 x 1000Base-T (PoE+) - RJ-45 , 1 x console - RJ-45 , 1 x USB 2.0 - Type A , 1 x 1000Base-T - RJ-45
VCCI, ICES-003, FCC Part 15.247, RSS-210, RSS-102, UL 2043, AES, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, EN50155, EMI, Directive 93/42/EEC, EN 300 328, FCC OET Bulletin 65c, TLS, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
PoE+
External power adapter
20.9 Watt
-20 °C
50 °C
10 - 90% (non-condensing)
CFBJ Cisco Ceiling Grip Clip In Stock £15.20
Speed: 1.7Gbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11a
Protocol: IEEE 802.11b
Protocol: IEEE 802.11ac (draft 5.0)
Compatibility: PC
Brand: Cisco
Price Range Ex VAT: £750 - £1000
