Cisco Aironet 1815I - Radio access point - 802.11ac Wave 2 -wifi
Quicklinx: F0TYWS00 Mfr#: AIR-AP1815I-E-K9C
  • IEEE 802.11n
Hurry, only 2 left in stock!
£147.15 ex VAT
£176.58 inc VAT
The Cisco Aironet 1815i delivers industry-leading wireless performance with support for the latest Wi-Fi standard, IEEE's 802.11ac Wave 2. It also meets the growing requirements of wireless networks by delivering a better user experience.
The 1815i extends support to a generation of Wi-Fi clients, such as smartphones, tablets, and high-performance laptops that have integrated 802.11ac Wave 1 or Wave 2 support.
  • MU-MIMO
    Multiuser (MU) multiple-input multiple-output (MU-MIMO) allows transmission of data to multiple 802.11ac Wave 2 - capable clients simultaneously to improve the client experience. Prior to MU-MIMO, 802.11n and 802.11ac Wave 1 access points could transmit data to only one client at a time, typically referred to as single-user MIMO. 802.11ac Wave 2 with 2x2:2 MIMO technology uses two spatial streams when operating in SU-MIMO or MU-MIMO mode, offering 867 Mbps rates for more capacity and reliability than competing access points.
  • Cisco Mobility Express solution (future availability)
    Flexible deployment through the Mobility Express solution is ideal for small to medium-sized deployments that require 25 or fewer access points. Easy setup allows the 1815i to be deployed on networks without a physical controller.
Cisco Aironet 1815I - radio access point
Radio access point
External
Belgium, Lebanon, Oman, Saudi Arabia, Bulgaria, Czech Republic, Estonia, Lithuania, Mongolia, Iceland, Romania, Sri Lanka, Luxembourg, Hungary, Cyprus, Iraq, Ghana, Kenya, Nigeria, Trinidad, Jamaica, Liechtenstein, Gibraltar, Malta, Monaco, Macedonia, Slovakia, Slovenia, Latvia, Libya, Austria, Denmark, Finland, France, Germany, Italy, Netherlands, Norway, Poland, Portugal, Spain, Sweden, Switzerland, United Kingdom, Greece, Turkey, Ireland, Bahamas, Serbia, Montenegro, Bosnia and Herzegovina
710 MHz
RAM
1 GB
Flash Memory
256 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets, Torx security screw
Power Over Ethernet (PoE) Supported
PoE
15.08 cm x 15.08 cm x 3.3 cm
400 g
Radio access point
15.08 cm
15.08 cm
3.3 cm
400 g
Processor / Memory / Storage
Processors Installed
710 MHz
RAM
1 GB
Flash Memory
256 MB
External
Wireless
Data Transfer Rate
1 Gbps
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Boot State, status
Wi-Fi Multimedia (WMM) support, Maximum Ratio Combining (MRC), dual-stream (2x2), 802.1x authentication, cyclic shift diversity (CSD), MU-MIMO technology, packet aggregation A-MPDU, packet aggregation A-MSDU, Dynamic Frequency Selection (DFS)
Encryption Algorithm
AES, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
RADIUS, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST, EAP-SIM
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45 , 1 x console - RJ-45
VCCI, ICES-003, FCC Part 15.247, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, EN 300 328, FCC OET Bulletin 65c, RSS-247, EN 301 893, EN 301 489-17
PoE
8.3 Watt
OS Provided
Limited warranty - advance hardware replacement - lifetime - response time: 10 days
32 °C
104 °C
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1Gbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Brand: Cisco
Price Range Ex VAT: 100 - 150
