Cisco 897VA Gigabit Ethernet Security Router with VDSL/ADSL2
Quicklinx: 9GFVWS00 Mfr#: C897VAW-E-K9
  • IEEE 802.11n (draft 2.0)
Cisco 890 series integrated services router is fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. It is designed to deliver secure broadband, Metro Ethernet, wireless LAN (WLAN) connectivity, and business continuity. The routers also come with powerful management tools, such as the web-based Cisco configuration professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
  • Secure network connectivity
    Cisco 890 series router delivers high performance with integrated security and threat defense. Network security has become a fundamental building block of any network, and Cisco routers play an important role in embedding security at the customer's access edge.
  • Metro Ethernet connectivity
    Cisco 890 series router is ideal for service provider deployments as Metro Ethernet customer premises equipment (CPE). The routers also provide failover protection and load balancing. The 8-port managed switch provides enough LAN ports for connecting multiple devices. The Cisco 890 Series provides significant value to customers by simplifying deployment of Ethernet WAN services with end-to-end OA&M, service-level agreement (SLA) monitoring and verification, and configuration management, resulting in increased operational efficiency and reduced operating expenses (OpEx).
  • High availability
    Cisco 890 series router enables customers to deliver high-performance, high-availability, mission-critical business applications. These capabilities include Virtual Router Redundancy Protocol (VRRP), Hot Standby Router Protocol (HSRP), MultigroupHSRP (MHSRP), and dial backup with external modem through a virtual auxiliary port. Cisco 890 series router is integrated with ISDN BRI, a V.92 analog modem, or a Gigabit Ethernet port for a secondary WAN backup connection. If the primary Ethernet-access WAN is disconnected, the router detects this failure and fails over to the secondary backup WAN.
  • Integrated wireless LAN capability
    The Cisco 890 series is ideal for enterprise small branch offices and small businesses that need to be connected to larger enterprise networks. These routers help extend corporate networks to secure remote sites while giving users access to the same applications found in a corporate office. They provide increased reliability for diversity of wireless data, voice, and video applications. When users require wireless LAN (WLAN) access, visibility and control of network security are even more critical at the remote site. The Cisco 890 series meets this need with a single device that combines integrated 802.11 a/g/n capabilities with security features such as Wi-Fi Protected Access (WPA), including authentication with IEEE 802.1X with Cisco Extensible Authentication Protocol (LEAP) and Protected EAP (PEAP), and encryption with WPA Temporal Key Integrity Protocol (TKIP).
Cisco 897VA Gigabit Ethernet Security Router with VDSL/ADSL2+ and Wireless - wireless router - DSL modem - 802.11a/b/g/n (draft 2.0) - desktop
Wireless router - DSL modem - 8-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
VDSL, ADSL2+
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
L2TP, RSVP, IPSec, FTP, DHCP, DNS, L2TPv3
Routing Protocol
OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, IGMPv3, GRE, policy-based routing (PBR), WCCP, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
Firewall protection, auto-sensing per device, DHCP support, NAT support, MDI/MDI-X switch, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, Intrusion Prevention System (IPS), Low-latency queuing (LLQ), Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), MIMO technology, Spanning Tree Protocol (STP) support, Virtual Route Redundancy Protocol (VRRP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Link Fragmentation and Interleaving (LFI), Dynamic Multipoint VPN (DMVPN), DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), DNS proxy, CleanAir technology, Bidirectional Forwarding Detection (BFD), DHCP relay, 2T3R MIMO technology, DHCP client, Hot Standby Router Protocol (HSRP) support, Ingress Layer 2 MAC Access Control Lists (ACLs), Call Admission Control (CAC), Flexible NetFlow (FNF)
IEEE 802.1D, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n (draft 2.0)
32.3 cm x 24.8 cm x 4.45 cm
1-year warranty
Wireless router - 8-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Encryption Algorithm
LEAP, DES, Triple DES, MD5, AES, TLS, PEAP, TTLS, TKIP, WPA, WPA2, PKI, 128-bit AES, 192-bit AES, 256-bit AES, WEP
Authentication Method
RADIUS, TACACS+, Extensible Authentication Protocol (EAP), EAP-FAST
IEEE 802.1D, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n (draft 2.0), CISPR 24, EN 61000-3-2, EN55022, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN 61000-6-1, AES, FCC CFR47 Part 15, Triple DES, DES, VCCI V-3, ICES-003 issue 4 Class B, ICES-003 issue 4 Class A
RAM
512 MB (installed) / 1 GB (max)
Flash Memory
256 MB (installed) / 256 MB (max)
Status Indicators
Port status, power
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
VDSL, ADSL2+
Protocols & Specifications
ITU G.991.2 (G.shdsl), ITU G.992.1 (G.DMT) Annex A
LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x SFP (mini-GBIC)
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced IP services
32.3 cm
24.8 cm
4.45 cm
Limited warranty - advance parts replacement - 1 year - response time: 10 days
10 - 85% (non-condensing)
