The Cisco 880 ISR provides Internet, VPN, data, and backup capability to corporate teleworkers and remote and small offices of fewer than 20 users. These routers are capable of bridging and multiprotocol routing between LAN and WAN ports, and provide advanced features such as antivirus protection.
- Cisco 887VA Annex A router with VDSL2/ADSL2+ over POTS 802.11n ETSI Compliant - router - DSL modem - desktop
- Router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, VDSL2
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet
- Capacity
- IPSec VPN tunnels: 20
- L2TP, IPSec, PPPoE, PPPoA, DHCP, DNS
- Routing Protocol
- RIP-1, RIP-2, HSRP, VRRP, GRE, policy-based routing (PBR)
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI
- Firewall protection, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, SPI, DiffServ support, MAC address filtering, Broadcast Storm Control, IPv6 support, IPS, LLQ, CBWFQ, WFQ, MIMO technology, STP support, ACL support, QoS, DHCP server, DNS proxy
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 32.5 cm x 26.4 cm x 4.4 cm
- 2.5 kg
- 1-year warranty
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- Encryption Algorithm
- LEAP, DES, Triple DES, MD5, SSL, TLS, PEAP, TTLS, TKIP, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, Radio Service Set ID (SSID), TACACS+, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, ETSI, VCCI-II, EN55024, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, AS/NZS 60950-1, CS-03, EN 60555-2, UL 60950-1, IEC 60950-1
- RAM
- 256 MB (installed) / 768 MB (max) - DDR2 SDRAM - SO-DIMM 200-pin
- Flash Memory
- 128 MB
- Status Indicators
- Port status, power
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2
- Expansion Slots
- 1 (total) / 1 (free) x SO-DIMM 200-pin
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced Security
- 32.5 cm
- 26.4 cm
- 4.4 cm
- 2.5 kg
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
