Cisco 8831 IP phone EU and Aus
Quicklinx: BF6CWS00 Mfr#: CP-8831-EU-K9=
£854.48 ex VAT
£1,025.37 inc VAT
The Cisco Unified IP Conference Phone 8831 enhances people-centric communications, combining superior high-definition (HD) audio performance and 360-degree coverage for all sizes of conference rooms and executive offices. It provides an audiophile sound experience with a full-duplex two-way wideband (G.722) audio hands-free speaker.
The IP Conference Phone 8831 is a simple, scalable solution that meets the challenges of the most diverse rooms. It provides flexible deployment options and expansion by using extension microphones that can be wired or wireless (Digital Equipment Cordless Telephone (DECT)) with a daisy-chain configuration of two units.
The IP Conference Phone 8831 has an industrial design with enhanced ergonomics that puts the user first. It offers a detached control panel so that the display may be easily viewed without having to move the entire unit. It also provides easy view of device mute status from all sides.
  • Expanded room coverage
    160-degree conical pattern provides even coverage of listening area. Four Hemi-Cardioid microphones are perfectly spaced so that they combine to provide a 180-degree pick-up pattern around the device. Speech is captured at the same level at all points around the Cisco Unified IP Conference Phone 8831.
  • Wired microphones
    These microphones extend the operational range of the Cisco Unified IP Conference Phone 8831 with even coverage around the periphery of the device with 7 feet of additional reach.
  • Wireless microphones
    DECT wireless microphones for the Cisco Unified IP Conference Phone 8831 provide additional coverage with the added flexibility of 300 feet of range.
  • Wired control panel
    The panel allows easy control of the unit and viewing of the display without having to move the entire unit.
Cisco Unified IP Conference Phone 8831 - conference VoIP phone
Conference VoIP phone
Compatible Platforms
Cisco Business Edition 3000, Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support
VoIP Protocols
SIP
Voice Codecs
G.711, G.722, G.729a, G.729ab, iLBC
Package Content
Conference phone console, Conferencing base unit
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome - Yes
Network Ports Qty
1 x Ethernet 10/100Base-TX
Compatible Software
Cisco Unified Communications Manager 7.1 or later
Australia, European Union
1-year warranty
Body Material
PC/ABS
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Programmable Buttons Qty
4
Indicators
Voice message waiting indicator, hold indicator, mute indicator
Additional Functions
Call timer, built-in clock
Additional Features
Noise reduction, music on hold
Conference Phone
Package Content
Echo cancellation
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP
Voice Codecs
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
128 bit AES, IEEE 802.1X
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, SRTP
Network Ports Qty
Compatible Software
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), automatic gain control (AGC)
Network Features
Class 3 PoE, Lightweight Directory Access Protocol (LDAP)
Display
Display Location
Base
Diagonal Size
3.5"
Display Resolution
396 x 162 pixels
Backlit
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
CISPR 24, BSMI CNS 13438 Class B, EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, AS/NZS 60950-1, AS/ACIF S004, UL 60950-1 Second Edition, AS/NZS 3548 Class B, EN 301 406, FCC CFR47 Part 15 D, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, GB 4943-2001 PSB, VCCI Class B
Dimensions & Weight (Base)
26.35 cm
5.08 cm
15.05 cm
1.587 kg
Limited warranty - 1 year
Type: Conference VoIP phone
Brand: Cisco
Price Range Ex VAT: £750 - £1000
