Cisco 867VAE Router DSL Modem 4-port Switch
Quicklinx: DHY3WS00 Mfr#: C867VAE-K9
Type: Router
Standards: Gigabit Ethernet, Ethernet, Fast Ethernet
Rackmount or External: Rack-mountable
£266.37 ex VAT
£319.64 inc VAT
An entry level member of the Cisco Integrated Services Router Generation 2 (ISR G2) family, the Cisco 867VAE Integrated Services Router offers connectivity to teleworkers and small branches.
  • Robust security
    Equipped with 10 IPSec VPN tunnels, the Cisco 867VAE offers a secure and reliable connection for transmitting sensitive data, ensuring your online activities remain private and protected.
  • Comprehensive connectivity
    This device boasts a variety of interfaces including Ethernet 10Base-T/100Base-TX for LAN and WAN connections, alongside an RJ-45 connector, providing versatile options for setting up and expanding your network.
  • Advanced networking capabilities
    With support for IPv6, NetFlow, and Class-Based Weighted Fair Queuing (CBWFQ), the Cisco 867VAE facilitates efficient data flow and network management, making it ideal for handling heavy traffic loads.
  • High-speed Internet access
    Featuring ADSL2+ and VDSL2 digital signaling protocols, the Cisco 867VAE delivers fast and reliable Internet access, ensuring smooth streaming, browsing, and downloading across your network.
  • Easy remote management
    Remote management protocols such as HTTP, HTTPS, SNMP 3, and SSH allow for convenient and secure configuration and monitoring of the device from anywhere, simplifying network administration tasks.
Cisco 867VAE - router - DSL modem - desktop, rack-mountable
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop, rack-mountable - 1U
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
2
IPSec VPN tunnels: 10
Network / Transport Protocol
IPSec, PPPoE, PPPoA, DHCP, DNS
Routing Protocol
RIP-1, RIP-2
Remote Management Protocol
SNMP 3, HTTP, HTTPS, SSH
Firewall protection, auto-uplink (auto MDI/MDI-X), IPv6 support, LLQ, CBWFQ, WFQ, DHCP server, DNS proxy, DHCP relay, WSMA, NetFlow, DHCP client
IEEE 802.1Q, IEEE 802.3ah
20.9 cm x 19.8 cm x 3.9 cm
2.5 kg
Router - 4-port switch (integrated)
Enclosure Type
Wired
Routing Protocol
RIP-1, RIP-2
IEEE 802.1Q, IEEE 802.3ah, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, EN 61000-4-3, EN 61000-4-6, AS/NZS 3548, FCC CFR47 Part 15, VCCI V-3
RAM
256 MB (installed) / 256 MB (max)
Flash Memory
64 MB
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2+, VDSL2
Protocols & Specifications
ITU G.994.1 (G.hs), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex B, ITU G.992.3 Annex B
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x ADSL2+ , USB: 1 x 4 pin USB Type A , WAN: 1 x VDSL2 , LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter - 60 Watt
OS Provided
Cisco IOS Advanced Security
20.9 cm
19.8 cm
3.9 cm
2.5 kg
10 - 85% (non-condensing)
DHY3 Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £35.18
DHY3 Cisco AC Power Cord In Stock £40.81
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Brand: Cisco
