Part of the Cisco Small Business Series, the SIP-based Cisco SPA501G Basic 8-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers.
With hundreds of features and configurable service parameters, the Cisco SPA501G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the Cisco SPA501G.
Comprehensive interoperability and sip-based feature set
Part of the Cisco Small Business Pro Series, the SIP- based Cisco SPA 501G Basic 8-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA 501G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the Cisco SPA 501G. -
Carrier-grade security, provisioning, and management
The Cisco SPA 501G uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
- Cisco Small Business SPA 501G - VoIP phone - 3-way call capability
- Product Type
- VoIP phone
- Main Features
- Multiple VoIP protocol support, integrated Ethernet switch
- VoIP Protocols
- SIP, SIP v2, SPCP
- Voice Codecs
- G.722, G.729a, G.711u, G.711a, G.726
- Lines Supported
- Multiline
- Intercom
- Speakerphone
- Yes (digital duplex)
- Voice Mail Capability
- Call Services
- Voice Mail, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Automatic Redial
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- Body Colour
- Silver, dark grey
- 1-year warranty
- Designed For
- Small Business Pro Unified Communications 320 with 4 FXO
- Product Type
- VoIP phone
- Body Colour
- Silver, dark grey
- Body Material
- ABS plastic
Phone Features
- Call Services
- Key Expansion Module Max Qty
- 2
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- 3-way
- Intercom
- Speakerphone
- Automatic Redial
- Function Buttons
- Conference button, speakerphone button, transfer button, headset button, mute button, hold button, auto redial button
- Programmable Buttons Qty
- 8
- Volume Control
- Ringer Control
- Indicators
- Voice message waiting indicator, speakerphone indicator, headset
- Firmware Upgradable
- Additional Functions
- Pager Call, Intercom, automatic redial
- Additional Features
- On-hook dialling, music on hold, built-in web server, paper label insert
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP, SIP v2, SPCP
- Voice Codecs
- Lines Supported
- Multiline
- Quality of Service
- IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
- IP Address Assignment
- DHCP
- Security
- 256 bit AES
- Power Over Ethernet (PoE) Support
- Network Protocols
- IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS
- Network Ports Qty
- Voice Features
- Comfort noise generation (CNG), voice activity detection (VAD), HD Voice
- Network Features
- Network Address Translation (NAT)
Phone Memory
- Phone Directory Capacity
- 100 names & numbers
- Call Log Capacity
- 60 numbers
- Connections
- Headset jack / sub-mini-phone 2.5mm
- Cables Included
- Network cable
- UL, C-Tick, CB, FCC Part 15 B, A-Tick
Dimensions & Weight (Base)
- 21.4 cm
- 4.4 cm
- 21.2 cm
- 0.9 kg
- Limited warranty - 1 year
- Designed For
- Cisco Small Business Pro Unified Communications 320 with 4 FXO
