- Cisco Config 1 Secondary Power Supply - power supply - hot-plug / redundant - 715 Watt
- Power supply - hot-plug / redundant - plug-in module
- 1.3 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- -56 V
- Power Capacity
- 715 Watt
- Input Connectors
- Power IEC 60320 C16
- 8.3 cm x 31 cm x 4 cm
- Designed For
- Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-48P-E, 3850-48P-L, 3850-48P-S
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Input Connectors
- Output Voltage
- -56 V
- Power Capacity
- 715 Watt
- MTBF
- 664,055 hours
- CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZ 3548 Class A, CCC, ICES-003 Class A, EN 61000-4-5, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, BSMI Class A, VCCI Class A
- -5 °C
- 45 °C
- 5 - 90% (non-condensing)
- 8.3 cm
- 31 cm
- 4 cm
- 1.3 kg
- Designed For
- Cisco Catalyst 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-48P-E, 3850-48P-L, 3850-48P-S
