Cisco 715W AC Config 1 Power Supply
Quicklinx: BW4NWS00 Mfr#: PWR-C1-715WAC=
£731.79 ex VAT
£878.14 inc VAT
  • Robust compatibility
    Designed specifically for network hardware, this power supply ensures seamless integration and operation within Cisco switch environments, providing a reliable power source for critical network infrastructures.
  • Wide operating range
    With an operating temperature range from -5°C to 45°C and humidity range operating from 5 - 90% (non-condensing), this power supply is built to perform reliably in a variety of environmental conditions, ensuring uninterrupted network performance.
  • Comprehensive compliance
    Meeting a broad spectrum of compliance standards including AS/NZ 3548 Class A, FCC Part 15 A, and EN 60950-1, this power supply adheres to rigorous safety and performance requirements, ensuring a high level of reliability and quality.
Cisco - power supply - hot-plug / redundant - 715 Watt
Power supply - hot-plug / redundant - plug-in module
1.3 kg
Input Voltage
AC 100-240 V
Output Voltage
-56 V
Power Capacity
715 Watt
Input Connectors
Power IEC 60320 C16
8.3 cm x 31 cm x 4 cm
Catalyst 3850-24P-BA, 3850-24P-E, 3850-24P-L, 3850-24P-S, 3850-24PW-S, 3850-32XS-E, 3850-32XS-S (715 Watt), 3850-48P-E (715 Watt), 3850-48P-L (715 Watt), 3850-48P-S (715 Watt), 3850-48PW-S (715 Watt), 9300 (715 Watt), 9300 (Higher Scale) (715 Watt), 9300L (715 Watt); ONE Catalyst 3850-24P, 3850-48P
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C16
Output Voltage
-56 V
Power Capacity
715 Watt
CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZ 3548 Class A, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, BSMI Class A, VCCI Class A, EN 300 386
-5 °C
45 °C
8.3 cm
31 cm
4 cm
1.3 kg
Cisco Catalyst 3850-24P-BA (715 Watt), 3850-24P-E (715 Watt), 3850-24P-L (715 Watt), 3850-24P-S (715 Watt), 3850-24PW-S (715 Watt), 3850-32XS-E (715 Watt), 3850-32XS-S (715 Watt), 3850-48P-E (715 Watt), 3850-48P-L (715 Watt), 3850-48P-S (715 Watt), 3850-48PW-S (715 Watt), 9300 (715 Watt), 9300 (Higher Scale) (715 Watt), 9300L (715 Watt) , Cisco ONE Catalyst 3850-24P (715 Watt), 3850-48P (715 Watt)
Brand: Cisco
Price Range Ex VAT: £500 - £750
