Cisco 500 Series Dual Radio Access Point
Reduced Price - Whilst Stocks Last!
Quicklinx: 95MJWS00 Mfr#: WAP561-E-K9
  • IEEE 802.11n
The Cisco 500 series access points use selectable or concurrent dual-band radios for improved coverage and user capacity. Gigabit Ethernet LAN interfaces with Power over Ethernet (PoE) support flexible installation and reduce cabling and wiring costs. Intelligent quality-of-service (QoS) features let you prioritize bandwidth-sensitive traffic for voice over IP (VoIP) and video applications. SmartSignal Antenna technology enables you to extend the reach of your wireless network by optimizing coverage, reception, and performance.
To provide secure guest access to visitors and other users, the Cisco 500 series access points support a captive portal with multiple authentication options and the ability to configure rights, roles, and bandwidth. A customized guest login page lets you present a welcome message and access details, and reinforces your brand with company logos.
The Cisco 500 series access points are easy to set up and use, with intuitive wizard-based configuration to get you up and running in minutes. An attractive design with flexible mounting options enables the access points to smoothly blend into any small business environment.
Cisco Small Business WAP561 - radio access point
Radio access point
External
Middle East, Africa, Europe
RAM
64 MB
Flash Memory
32 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
23 cm x 23 cm x 2.5 cm
0.64 kg
Radio access point
23 cm
23 cm
2.5 cm
0.64 kg
Processor / Memory / Storage
RAM
64 MB
Flash Memory
32 MB
External
Wireless
Data Transfer Rate
450 Mbps
Spread Spectrum Method
OFDM
Network / Transport Protocol
DHCP, Bonjour
Remote Management Protocol
SNMP 3, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, LAN, wireless
Auto-sensing per device, load balancing, VLAN support, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, IPv4 support, rogue access point detection, DHCP client, ceiling mountable
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
10
Gain Level
5 dBi
1 x 1000Base-T - RJ-45
1 x network cable
Mounting Kit
Included
ICES-003, EN 300.328, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, AS/NZS 4268, EN 301.893, FCC Part 15.407, CAN/CSA C22.2 No. 60950-1
PoE
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
95MJ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
95MJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.22
95MJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.89
95MJ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.31
