The Cisco 500 series access points use selectable or concurrent dual-band radios for improved coverage and user capacity. Gigabit Ethernet LAN interfaces with Power over Ethernet (PoE) support flexible installation and reduce cabling and wiring costs. Intelligent quality-of-service (QoS) features let you prioritize bandwidth-sensitive traffic for voice over IP (VoIP) and video applications. SmartSignal Antenna technology enables you to extend the reach of your wireless network by optimizing coverage, reception, and performance.
To provide secure guest access to visitors and other users, the Cisco 500 series access points support a captive portal with multiple authentication options and the ability to configure rights, roles, and bandwidth. A customized guest login page lets you present a welcome message and access details, and reinforces your brand with company logos.
The Cisco 500 series access points are easy to set up and use, with intuitive wizard-based configuration to get you up and running in minutes. An attractive design with flexible mounting options enables the access points to smoothly blend into any small business environment.
- Cisco Small Business WAP561 - radio access point
- Radio access point
- Form Factor
- External
- Localisation
- Middle East, Africa, Europe
- RAM
- 64 MB
- Flash Memory
- 32 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 23 cm x 23 cm x 2.5 cm
- 0.64 kg
- Limited lifetime warranty
- 23 cm
- 23 cm
- 2.5 cm
- 0.64 kg
- Localisation
Processor / Memory / Storage
- RAM
- 64 MB
- Flash Memory
- 32 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Spread Spectrum Method
- OFDM
- DHCP, Bonjour
- Remote Management Protocol
- SNMP 3, HTTPS
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, LAN, wireless
- Auto-sensing per device, load balancing, VLAN support, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, IPv4 support, rogue access point detection, DHCP client, ceiling mountable
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 10
- Gain Level
- 5 dBi
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- ICES-003, EN 300.328, FCC Part 15.247, RSS-210, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15.107, FCC Part 15.109, AS/NZS 4268, EN 301.893, FCC Part 15.407, CAN/CSA C22.2 No. 60950-1
- PoE
- OS Provided
- Linux
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.20 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £11.64 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £7.15 |
