Every wireless LAN deployment is different. When engineering an in-building solution, varying facility sizes, construction materials, and interior divisions raise transmission and multipath considerations. When implementing a building-to-building solution, distance, physical obstructions between facilities, and number of transmission points must be taken into account.
Cisco is committed to providing the best access points, client adapters, and bridges in the industry - and is also committed to providing a complete solution for any wireless LAN deployment. Cisco has the widest range of antennas, cable, and accessories available from any wireless manufacturer.
The Cisco Aironet AIR-ANT5135DG-R is a 5 GHz antenna for access point and bridge equipment that enables a customized wireless solution for almost any installation.
- Cisco Aironet antenna
- Product Type
- Antenna
- 1.5 cm 9.2 cm
- 28 g
- Grey
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Indoor
- Compatibility
- 802.11 a
- Frequency Range
- 5 GHz
- Gain
- 3.5 dBi
- Directivity
- Omni-directional
- Designed For
- Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
- Product Type
- Antenna
- 1.5 cm
- 9.2 cm
- 28 g
- Enclosure Colour
- Grey
Aerial
- Intended For
- Wi-Fi
- Indoor
- Compatibility
- 802.11 a
- Frequency Range
- 5 GHz
- Gain
- 3.5 dBi
- Directivity
- Omni-directional
- Horizontal Beamwidth
- 360°
- Vertical Beamwidth
- 40°
Cabling & Wiring
- Connector Provided
- 1 x RP-TNC male
- 0 °C
- 55 °C
- Designed For
- Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
