This antenna operates in the 5-GHz frequency band and is designed for use with Cisco Aironet access points and bridges but can be used with any 5-GHz Cisco Aironet radio device that uses RP-TNC connectors. The antenna has an articulated base that can be rotated 360 degrees at the connection point and from 0 to 90 degrees at its knuckle with detents at 45 and 90 degrees.
- Cisco Aironet Articulated Dipole - antenna
- Product Type
- Antenna
- 1.5 cm 13.5 cm
- 28 g
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Indoor
- Compatibility
- 802.11 a
- Frequency Range
- 5 GHz
- Gain
- 3.5 dBi
- Directivity
- Omni-directional
- Designed For
- Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
- Product Type
- Antenna
- 1.5 cm
- 13.5 cm
- 28 g
- Enclosure Colour
- White
Aerial
- Intended For
- Wi-Fi
- Indoor
- Compatibility
- 802.11 a
- Frequency Range
- 5 GHz
- Gain
- 3.5 dBi
- Directivity
- Omni-directional
- Horizontal Beamwidth
- 360°
- Vertical Beamwidth
- 40°
Cabling & Wiring
- Connector Provided
- 1 x RP-TNC
- 0 °C
- 55 °C
- Designed For
- Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
