Your basket is empty
Cisco 48 Watt Power Adapter
Quicklinx: 8B6NWS00 Mfr#: PSU-CAM-V=
SAC SA150B-12V - power adapter - 48 Watt
Power adapter - external
0.28 kg
Input Voltage
AC 100-240 V
Output Voltage
12 V
Power Capacity
48 Watt
Input Connectors
Power IEC 60320 C14
5 cm x 11 cm x 3.1 cm
Environmental Standards
ENERGY STAR
TelePresence PrecisionHD Camera, PrecisionHD USB Camera; TelePresence System 1000 MXP, 1700 MXP, Edge 75 MXP, Edge 95 MXP
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
47 - 63 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
12 V
Max Electric Current
4 A
Power Capacity
48 Watt
Power cable 1.5 m
MTBF
50,000 hours
Over current protection, over voltage protection, short-circuit protection
UL, TUV GS, cUL, CB, CCC, PSE Mark, CEC
ENERGY STAR
20 - 80% (non-condensing)
5 cm
11 cm
3.1 cm
0.28 kg
Cisco TelePresence PrecisionHD Camera, PrecisionHD USB Camera , Cisco TelePresence System 1000 MXP, 1700 MXP, Edge 75 MXP, Edge 95 MXP
