Product
Cisco 48-port 10/100 M.Switch wGigab
Quicklinx: 75G7WS00 Mfr#: SRW248G4-K9-UK
Type: Fast Ethernet
Ports: 48
Data Transfer Rate: 100Mbps
Managed: Yes
POE: [N/A]
£410.16 ex VAT
£492.19 inc VAT
Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switch provides a powerful foundation to support your business network.
  • High performance and reliability
    Get the high availability and performance you need to support vital business applications while reducing downtime.
  • Advanced features
    Control network traffic with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support.
  • Easy setup and management
    Intuitive browser-based tools, mass deployment capabilities, and consistent features simplify setup and configuration.
  • An eco-friendly solution
    Switch optimizes power usage for energy efficiency without compromising performance.
  • Energy efficiency and design
    Support of Energy Efficient Ethernet (EEE) and reduction of energy consumption by monitoring traffic and putting links into sleep mode during quiet periods.
Cisco Small Business SF300-48 - switch - 48 ports - Managed
Switch - 48 ports - L3 - Managed
Enclosure Type
1U
Subtype
Fast Ethernet
Ports
48 x 10/100 + 2 x combo Gigabit SFP + 2 x 10/100/1000
MAC Address Table Size
8K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 35 cm x 4.5 cm
3.4 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Enclosure Type
Desktop 1U
Subtype
Fast Ethernet
Ports
8K entries
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB Flash
Status Indicators
Port transmission speed, system, link/activity
48 x 100Base-TX RJ-45 , 1 x console DB-9 management , 4 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
44 cm
35 cm
4.5 cm
3.4 kg
Limited warranty - replacement - lifetime - response time: next business day
10 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 48
Managed: Yes
POE: [N/A]
Brand: Cisco
Price Range Ex VAT: 300 - 500
