Your basket is empty
Cisco 4500 E-SERIES SUP 6-E
Quicklinx: 74L1WS00 Mfr#: WS-X45-SUP6-E=
The Cisco Catalyst 4500 Supervisor Engine 6-E with CenterFlex technology is an intelligent, high-performance, next-generation extension to the Cisco Catalyst 4500 Series optimized for customers deploying business-critical applications. CenterFlex technology is enabled by Cisco developed application-specific integrated circuits (ASICs) specific to the Supervisor Engine 6-E that deliver industry-leading centralized performance and configuration flexibility. CenterFlex technology helps enable granular optimization of real-time voice, video, and data communications to ensure workforce productivity and profitability and customer success for organizations of all sizes.
Cisco Supervisor Engine 6-E - control processor
Control processor
Plug-in module
1 x 1.3 GHz
RAM
512 MB (installed) / 1 GB (max)
Ports Qty
2
10 Gigabit Ethernet
Performance
Switching capacity: 320 Gbps , IPv4 routing: 250 Mbps , IPv6 routing: 125 Mbps
QoS hardware entries: 64000 , Security services entries: 64000 , Hardware forwarding entries: 256000 , Multicast entries (IPv4): 128000 , Multicast entries (IPv6): 64000 , MAC addresses: 55000 , Virtual interfaces (VLANs): 4096 , IPv6 routes: 128000 , IPv4 routes: 256000
Cisco IOS 12.2(40)SG
Catalyst 4503-E, 4506-E, 4507R-E, 4510R-E
Control processor
Installed Modules Qty (Max)
0 (2)
Processor / Memory / Storage
Processors Installed
1 x 1.3 GHz
RAM
512 MB (1 GB max) SDRAM
Plug-in module
Ports Qty
2
Wired
10 Gigabit Ethernet
Switching Protocol
Ethernet
Network / Transport Protocol
NTP, ICMP/IP
Routing Protocol
OSPF, RIP, BGP-4, RIP-2, BGP, EIGRP, HSRP, IGMP, DVMRP, VRRP, PIM-SM, static IP routing, GRE, OSPFv3, PIM-SSM, Multiprotocol BGP, MSDP, RIPng, MLDv2, MLD
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3
Performance
Status Indicators
Bandwidth utilization %, link OK, status, link/activity
Auto-negotiation, VLAN support, IGMP snooping, IPv6 support, DHCP snooping, Dynamic Trunking Protocol (DTP) support, Access Control List (ACL) support, Quality of Service (QoS), Multicast Suppression, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), MLD snooping
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP)
Communications
Supported Flash Memory Cards
CompactFlash Card
Expansion Slots
2 (total) / 2 (free) x X2
1 x management - RJ-45 , 1 x 1000Base-T (management) - RJ-45 , 1 x USB - Type A , 1 x USB - Type B
Compatible Slots
1 x Expansion Slot
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, EN55022, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, CSA 22.2 No. 60950, ACA TS001, AS/NZS 3260, ICES-003 Class A, FCC CFR47 Part 15
10 - 90%
Cisco Catalyst 4503-E, 4506-E, 4507R-E, 4510R-E
74L1 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
74L1 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
74L1 C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
74L1 C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
