Product
Cisco 4 Line IP Phone With Display PoE and PC Port
Intuitive, easy-to-use phone features
Quicklinx: 6JHDWS00 Mfr#: SPA504G
More than 50 in stock
£73.58 ex VAT
£88.29 inc VAT
Part of the Cisco Small Business Series, the SIP-based Cisco SPA 504G 4-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers.
With hundreds of features and configurable service parameters, the Cisco SPA 504G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the SPA 504G.
PSU Not Included
  • Comprehensive interoperability and sip-based feature set
    Part of the Cisco Small Business Pro Series, the SIP-based Cisco SPA 504G 4-Line IP Phone has been tested to ensure comprehensive interoperability with equipment from voice over IP (VoIP) infrastructure leaders, enabling service providers to quickly roll out competitive, feature-rich services to their customers. With hundreds of features and configurable service parameters, the Cisco SPA 504G addresses the requirements of traditional business users while building on the advantages of IP telephony. Features such as easy station moves and shared line appearances (across local and geographically dispersed locations) are just some of the many advantages of the SPA 504G.
  • Carrier-grade security, provisioning, and management
    The Cisco SPA 504G uses standard encryption protocols to perform highly secure remote provisioning and unobtrusive in-service software upgrades. Remote provisioning tools include detailed performance measurement and troubleshooting features, enabling network providers to deliver high-quality support to their subscribers. Remote provisioning also saves service providers the time and expense of managing, preloading, and reconfiguring customer premises equipment.
Cisco Small Business SPA 504G - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
G.722, G.729a, G.711u, G.711a, G.726
Lines Supported
Multiline
Intercom
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Automatic Redial
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
Silver, dark grey
1 year warranty
Small Business Pro Unified Communications 320 with 4 FXO
VoIP phone
Body Colour
Silver, dark grey
Body Material
ABS plastic
Phone Features
Call Services
Key Expansion Module Max Qty
2
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Intercom
Speakerphone
Automatic Redial
Menu Operation
Function Buttons
Conference button, speakerphone button, transfer button, headset button, mute button, hold button, auto redial button
Programmable Buttons Qty
4
Volume Control
Ringer Control
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer, built-in clock, Pager Call, Intercom, automatic redial
Additional Features
On-hook dialling, music on hold, built-in web server
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SIP v2, SPCP
Voice Codecs
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP
Security
256 bit AES
Power Over Ethernet (PoE) Support
Network Protocols
IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), HD Voice
Network Features
Network Address Translation (NAT)
Phone Memory
Phone Directory Capacity
100 names & numbers
Call Log Capacity
60 numbers
Display
Display Location
Base
Display Resolution
128 x 64 pixels
Backlit
Headset jack / sub-mini-phone 2.5mm
Network cable
UL, C-Tick, CB, FCC Part 15 B, A-Tick
Dimensions & Weight (Base)
21.4 cm
4.4 cm
21.2 cm
0.9 kg
Limited warranty - 1 year
Cisco Small Business Pro Unified Communications 320 with 4 FXO
6JHD C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
6JHD C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
6JHD C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.64
6JHD Cisco Small Business power adapter In Stock £6.57
6JHD C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.36
Brand: Cisco
Price Range Ex VAT: 50 - 100
