Cisco 28-port Gigabit Managed Switch
Quicklinx: 75GJWS00 Mfr#: SRW2024-K9-UK
Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switch provides a powerful foundation to support your business network.
  • High performance and reliability
    Get the high availability and performance you need to support vital business applications while reducing downtime.
  • Advanced features
    Control network traffic comes with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support.
  • Easy setup and management
    Intuitive browser-based tools, mass deployment capabilities, and consistent features across all models simplify setup and configuration.
  • An eco-friendly solution
    Switches optimize power usage for energy efficiency without compromising performance.
Cisco Small Business SG300-28 - switch - 26 ports - Managed
Switch - 26 ports - L3 - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
26 x 10/100/1000 + 2 x combo Gigabit SFP
MAC Address Table Size
8K entries
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
44 cm x 25.7 cm x 4.5 cm
3.3 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
8K entries
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB Flash
Status Indicators
Port transmission speed, system, link/activity
28 x 1000Base-T RJ-45 , 1 x console DB-9 management , 2 x SFP (mini-GBIC)
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
179,141 hours
UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
44 cm
25.7 cm
4.5 cm
3.3 kg
Limited warranty - replacement - lifetime - response time: next business day
10 - 90% (non-condensing)
75GJ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
75GJ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
75GJ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.07
75GJ C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
