Cisco 250 Series SG250-50HP 48-port Smart Gigabit Ethernet Switch
Quicklinx: DXBWWS00 Mfr#: SG250-50HP-K9-UK
Type: Gigabit Ethernet
Ports: 50
Managed: Yes
POE: PoE+
£560.44 ex VAT
£672.52 inc VAT
Next-generation 250 Series Smart Switches combine powerful performance and reliability with a suite of features that you need for a solid business network. With Smart Network Application, FindIT Network Manager, and Network Plug and Play (PnP) support, you can deploy and configure a complete business network in minutes.
  • ETHERNET PORT CONFIGURATION
    48-port 10/100/1000, 2 x 1G combo SFP
  • POWER OVER ETHERNET
    48 PoE ports with 192W total power budget, PoE, PoE+
  • CONFIGURATION & CONTROL
    Easy-to-use on-box WebUI, CLI offers basic+ capabilities, SNMP, Cisco FindIT Network Manager, PnP, auto-discovery, zero-touch deployment
  • L2+ FEATURES AND SECURITY
    Static routing, VLANs, QoS, Voice VLAN, MSTP, IGMP Snooping Access Control List (ACL), 802.1X, DoS prevention, SSH/SSL
  • PEACE OF MIND
    Limited-lifetime warranty, one-year technical support, and free software fixes for the term of the warranty
Cisco 250 Series SG250-50HP - switch - 50 ports - smart - rack-mountable
Switch - 50 ports - L3 - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x combo Gigabit Ethernet/Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
192 W
Performance
Switching capacity: 100 Gbps , Switching capacity (64-byte packet size): 74.41 Mpps
MSTP instances: 8 , Active VLANs: 256 , QoS hardware queues: 4
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD, CIDR
Remote Management Protocol
SNMP, RMON, Telnet, HTTP, HTTPS, TFTP, SSH
DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, 24 MB packet buffer, SNMP support, 2 fans, Cisco Discovery Protocol
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
AC 120/230 V (50 - 60 Hz)
44 cm x 35 cm x 4.4 cm
4.8 kg
Kuwait, Qatar, Saudi Arabia, Hong Kong, Malaysia, Singapore, United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
192 W
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS
X ARM: 800 MHz
RAM
512 MB
Flash Memory
256 MB
Status Indicators
System, link/speed
48 x 1000Base-T RJ-45 PoE+ - 192 W , 2 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP , 1 x USB Type A management
Internal power supply
Rack Mounting Kit
Included
MTBF
62,607 hours
UL 60950, FCC Part 15 A, CSA 22.2
44 cm
35 cm
4.4 cm
4.8 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 50
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: 500 - 750
