Cisco small business 200 series smart switches combine powerful network performance with reliability to help you build a basic business network. Affordable and easy to use, these entry-level, web-managed switches deliver the essential network features you need. Enjoy speedy file transfers, keep vital business applications available, and help your employees respond faster to customers and each other.
Easy configuration and management
Cisco 200 series switches are designed to be easy to deploy and use by small businesses or the partners that serve them. Simple-to-use web-based interfaces reduce the time it takes to deploy, manage, and troubleshoot your network. -
Performance and reliability
Cisco 200 series switches have been tested to deliver the high availability and performance you would expect from a Cisco switch and help you prevent costly downtime. The switches speed file transfer times, improve slow and sluggish networks, keep your vital business applications available, and help your employees respond more quickly to customers and each other. With a network based on Cisco 200 series switches, you can address all of your business communications and connectivity needs and reduce the total cost of ownership of your technology infrastructure. -
Power over Ethernet (PoE)
This capability simplifies the deployment of IP telephony, wireless, video surveillance, and other solutions by allowing you to send data and power to network endpoints over the same network cable. With no need for separate power supplies or outlets for IP phones, IP cameras, or wireless access points, you can speed up deployment and installation and take advantage of advanced communications technologies quickly, and at a lower cost. -
Network security
Cisco 200 series switches provide security and network management features you need to maintain a high level of security for your business, keep unauthorized users off the network, and protect your business data. The switches provide integrated network security to reduce the risk of a security breach, with IEEE 802.1X port security to control access to your network. Denial-of-service (DOS) attack prevention increases network uptime in the presence of an attack. -
IP telephony support
Cisco 200 series switches include QoS features to prioritize delay-sensitive services such as voice and video, simplify unified communications deployments, and help ensure consistent network performance for all services. -
Networkwide automatic voice deployment
Using a combination of Cisco discovery protocol, LLDP-MED, auto smartports, and voice services discovery protocol (VSDP) - a unique patent-pending Cisco protocol - customers can deploy an end-to-end voice network dynamically. The switches in the network automatically converge into a single voice VLAN and set of QoS parameters and then propagate them out to the phones on the ports where they are discovered. For example, automated voice VLAN capabilities let you plug any IP phone (including third-party phones) into your IP telephony network and receive an immediate dial tone. The switch automatically configures the device with the right VLAN and QoS parameters to prioritize voice traffic. -
IPv6 support
As the IP network addressing scheme evolves to accommodate more devices, you can make sure that your network is ready. Cisco 200 series switches provide native support for IPv6 alongside traditional IPv4. That means you can take full advantage of IPv6-enabled operating systems and applications in the future, without having to upgrade your network equipment. -
An energy-efficient solution
Cisco 200 series switches are designed to be energy efficient and eco-friendly without compromising performance. They help conserve energy by optimizing power use, which helps protect the environment and lowers your energy costs.
- Cisco Small Business Smart SF200-24FP - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE) + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 180 W
- Performance
- Forwarding performance (64-byte packet size): 6.55 Mpps , Switching capacity: 8.8 Gbps
- MAC Address Table Size
- 8000 entries
- Jumbo Frame Support
- 10000 bytes
- Remote Management Protocol
- RMON, HTTP, TFTP
- Layer 2 switching, DHCP support, PoE, BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, TFTP support, QoS, Jumbo Frames support, MLD snooping
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.4 cm
- 3.45 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- PoE Budget
- 180 W
- Performance
- 8000 entries
- 10000 bytes
- RMON, HTTP, TFTP
- Encryption Algorithm
- MD5
- Authentication Method
- RADIUS
- RAM
- 128 MB
- Flash Memory
- 16 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 24 x 100Base-TX RJ-45 PoE , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
- Power Device
- Internal power supply
- Voltage Required
- UL 60950, FCC Part 15 A, CSA 22.2
- Localisation
- United Kingdom
- 44 cm
- 25.7 cm
- 4.4 cm
- 3.45 kg
- Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
