Cisco Aironet 2.4-GHz access point antennas are compatible with all Cisco RP-TNC-equipped access points. The antennas are available with different gain and range capabilities, beam widths, and form factors. Coupling the appropriate antenna and access point allows for efficient coverage in any facility, as well as better reliability at higher data rates.
- Cisco Aironet Articulated Dipole - antenna
- Product Type
- Antenna
- 14 cm
- 31 g
- White
- Gain
- 2.2 dBi
- Directivity
- Omni-directional
- Designed For
- 1000 Series Lightweight Access Point; Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250, 1252AG, 1252G, 1260, 1310, 1310G
- Product Type
- Antenna
- 14 cm
- 31 g
- Enclosure Colour
- White
Aerial
- Gain
- 2.2 dBi
- Directivity
- Omni-directional
Cabling & Wiring
- Connector Provided
- 1 x RP-TNC male
- Designed For
- Cisco 1000 Series Lightweight Access Point AIR-AP1020, AIR-AP1030 , Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based), 1310 Outdoor Access Point/Bridge, 1310G Outdoor
