The AIR-ANTM2050D-R antenna operates in the 2.4- and 5-GHz bands, and is designed for use with spatial-diversity access point (AP) systems. The AIR-ANTM2050D-R antenna is compatible with Cisco 802.11a/b/g radio products using a reverse-polarity threaded Neill-Concelman (RP-TNC) connector.
- Cisco Multiband Swivel-Mount Dipole Antenna - antenna
- Product Type
- Antenna
- 2.2 cm x 0.8 cm x 17.5 cm
- 50 g
- Directivity
- Omni-directional
- Designed For
- Cisco 1811, 1812, 1841
- Product Type
- Antenna
- 2.2 cm
- 0.8 cm
- 17.5 cm
- 50 g
Aerial
- Directivity
- Omni-directional
Cabling & Wiring
- Connector Provided
- 1 x RP-TNC
- Designed For
