The platforms are architected to enable the next phase of branch-office evolution, providing rich media collaboration and virtualization to the branch while maximizing operational cost savings The Integrated Services Routers Generation 2 platforms are future-enabled with multicore CPUs, Gigabit Ethernet switching with enhanced POE, and energy monitoring and control capabilities while enhancing overall system performance. Overall, the Cisco 1900 series offer unparalleled total cost of ownership savings and network agility through the intelligent integration of market leading security, unified communications, wireless, and application services.
This Cisco 1900 series integrated services router offers embedded hardware encryption acceleration, optional firewall, intrusion prevention, and application services. In addition, the platforms support the industries widest range of wired and wireless connectivity options such as T1/E1, xDSL, 3G, and GE.
Service integration
The Cisco 1941 series offer increased levels of services integration with data, security, and wireless and mobility services enabling greater efficiencies cost savings. -
Services on demand
The Cisco Services Ready Engine (SRE) enables a operational model which allows you to reduce capital expenditures (CapEx) and deploy a variety of application services as needed on a single integrated compute services module. -
High performance with integrated services
The Cisco 1900 series enables deployment in high speed WAN environments with concurrent services enabled up to 25 Mbps. Multi-Gigabit Fabric enables high bandwidth module to module communication without compromising routing performance -
Network agility
Designed to address customer business requirements, Cisco 1941 series with the modular architecture, offers performance range of modular interfaces and services as your network needs grow. Modular interfaces offer increased bandwidth, a diversity of connection options, and network resiliency. -
Energy efficiency
The Cisco 1900 series offers intelligent power management and allows the customer to control power to the modules based on the time of day. Cisco EnergyWise technology will be supported in the future. Services integration and modularity on a single platform performing multiple functions, optimizes raw materials consumption and energy usage.
- Cisco 1941 - router - desktop, rack-mountable
- Router
- Enclosure Type
- Desktop, rack-mountable - modular - 2U
- Data Link Protocol
- IPSec, PPPoE, L2TPv3
- Routing Protocol
- OSPF, IS-IS, BGP, EIGRP, DVMRP, PIM-SM, IGMPv3, GRE, PIM-SSM, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), MPLS, Bidirectional Forwarding Detection (BFD), IPv4-to-IPv6 Multicast
- Remote Management Protocol
- SNMP, RMON
- Firewall protection, VPN support, MPLS support, Syslog support, content filtering, IPv6 support, CBWFQ, WRED, DMVPN, WSMA, NetFlow
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824
- Power
- AC 120/230 V (50/60 Hz)
- 34.3 cm x 29.2 cm x 8.9 cm
- 5.4 kg
- 1-year warranty
- Router
- Enclosure Type
- Connectivity Technology
- Wired
- Routing Protocol
- SNMP, RMON
- Encryption Algorithm
- SSL
- IEEE 802.3, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3ah, IEEE 802.1ah, IEEE 802.1ag, ANSI T1.101, ITU-T G.823, ITU-T G.824, CISPR 22 Class A, CISPR 24, EN55024, EN55022 Class A, EN50082-1, AS/NZS 60950-1, ICES-003 Class A, CS-03, R&TTE, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, AS/NZS 3548 Class A, VCCI V-3, EN 61000, TIA/EIA/IS-968, EN 300 386, CAN/CSA-C22.2 No. 60950-1
- RAM
- 2 GB (installed) / 2 GB (max)
- Flash Memory
- 256 MB (installed) / 8 GB (max)
- Status Indicators
- Power, link/activity
- 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , Management: 1 x console - mini-USB Type B , Serial: 1 x auxiliary - RJ-45 , USB: 2 x 4 pin USB Type A
- Expansion Slots
- 2 (total) / 2 (free) x EHWIC , 2 (total) / 1 (free) x CompactFlash , 1 (total) / 1 (free) x ISM
- Power Device
- Internal power supply
- Voltage Required
- Rack Mounting Kit
- Included
- OS Provided
- Cisco IOS IP Base
- 34.3 cm
- 29.2 cm
- 8.9 cm
- 5.4 kg
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 85%
