Cisco 100FX SPF GE SFP Port for DSBU
Quicklinx: 4HQRWS00 Mfr#: GLC-GE-100FX=
Type: Modules
£163.36 ex VAT
£196.03 inc VAT
The Cisco 100BASE-FX Small Form-Factor Pluggable (SFP) Fast Ethernet Interface Converter (GLC-GE-100FX=) is a hot-swappable device that plugs into a Gigabit Ethernet SFP port on Cisco switches. The Cisco SFP provides full-duplex 100-Mbps connectivity between switches over multimode fiber (MMF) infrastructures. It offers investment protection and an easy migration path for customers moving to Gigabit Ethernet connections in the future.
The 100BASE-FX SFP operates on ordinary multimode fiber optical link spans of up to 2 kilometers in length. Customers implementing Cisco 100BASE-FX SFP can use 1000BASE-X SFPs in the future (including SX, LX/LH, ZX, and coarse wavelength-division multiplexing SFPs).
Cisco - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
1.34 cm x 5.65 cm x 8.5 mm
90 days warranty
Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, 2970G-24, 3560-24, 3560-48, 3560E-12, 3560E-24, 3560E-48, 3560G-24, 3560G-48, 3560V2-24, 3560V2-48, 3560X-24, 3560X-48, 3750-24, 3750-48, 3750G-12, 3750G-24
Plug-in module
Wired
Cabling Type
100Base-FX
100Mb LAN
Optical Wave Length
1310 nm
2 km
IEEE 802.3u, IEEE 802.3z, IEEE 802.3ah
1 x Ethernet 100Base-FX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
FCC CFR21 Part 1040, IEC 60825-1
1.34 cm
5.65 cm
8.5 mm
Limited warranty - 90 days
70 °C
Cisco Catalyst 2960-24LC-S, 2960-24PC-L, 2960-24PC-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, 2970G-24TS, 3560-24PS, 3560-24PS EMI, 3560-24PS SMI, 3560-24TS, 3560-24TS EMI, 3560-24TS SMI, 3560-48PS, 3560-48PS SMI, 3560-48TS, 3560-48TS EMI, 3560-48TS SMI, 3560E-12D, 3560E-12SD-E, 3560E-12SD-S, 3560E-24PD, 3560E-24TD, 3560E-48PD, 3560E-48PD-F, 3560E-48TD, 3560E-48TD-SD, 3560G-24PS, 3560G-24PS EMI, 3560G-24PS SMI, 3560G-24TS, 3560G-24TS EMI, 3560G-24TS SMI, 3560G-48, 3560G-48PS, 3560G-48PS SMI, 3560G-48TS, 3560G-48TS EMI, 3560G-48TS SMI, 3560V2-24PS, 3560V2-24TS, 3560V2-24TS-SD, 3560V2-48PS, 3560V2-48TS, 3560X-24P-L, 3560X-24P-S, 3560X-24T-L, 3560X-24T-S, 3560X-48PF-L, 3560X-48PF-S, 3560X-48P-L, 3560X-48P-S, 3560X-48T-L, 3560X-48T-S, 3750-24PS, 3750-24PS EMI, 3750-24PS SMI, 3750-24TS, 3750-24TS-E, 3750-48PS, 3750-48TS, 3750-48TS-E, 3750-48TS-S, 3750G-12S-E, 3750G-12S-S, 3750G-24T-S, 3750G-24TS EMI, 3750G-24TS SMI, 3750G-24TS-S
4HQR C2G 2m SC-SC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £15.04
4HQR C2G 2m LC-LC 10Gb 50/125 OM3 Duplex Multimode PVC Fibre Optic Cable (LSZH) - Aqua In Stock £18.07
Type: Modules
Brand: Cisco
