The Cisco 10/100 8-Port VPN Router is an advanced Internet-sharing network solution for your small business needs. Like any router, it lets multiple computers in your office share an Internet connection. But the unique dual Internet ports on the 10/100 8-Port VPN Router let you connect a second Internet line as a backup to insure that you're never disconnected. Or, use both Internet ports at the same time, and let the router balance your office's requirements between them for maximum bandwidth efficiency.
The 10/100 8-Port VPN Router also features a built-in 8-port full-duplex 10/100 Ethernet switch to connect eight PCs directly, or you can connect more hubs and switches to create as big a network as you need.
The Virtual Private Network (VPN) capability creates encrypted "tunnels" through the Internet, allowing up to 50 remote offices or traveling users to securely connect into your office network from off-site. Users connecting through a VPN tunnel are attached to your company's network - with secure access to files, e-mail, and your intranet - just as if they were in the building. You can also use the VPN capability to allow users on your small office network to securely connect out to a corporate network.
The 10/100 8-Port VPN Router can serve as a DHCP Server, and has a powerful SPI firewall to protect your PCs against intruders and most known Internet attacks. It can be configured to filter internal users' access to the Internet, and has IP address filtering so you can specify exactly who has access to your network. Configuration is a snap with the web browser-based configuration utility.
As the heart of your small office network, the connection-redundant Linksys 10/100 8-Port VPN Router gives you the connection reliability your business needs.
- Cisco Small Business RV082 - router - desktop
- Router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet
- Performance
- NAT throughput: 200 Mbps , VPN throughput (IPSec): 97 Mbps
- Capacity
- IPSec VPN tunnels: 100 , PPTP VPN tunnels: 5 , VPN tunnels (remote access): 50
- PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, HTTPS
- Firewall protection, switching, DMZ port, routing, NAT support, VPN support, PAT support, load balancing, VLAN support, Stateful Packet Inspection (SPI), content filtering, Quality of Service (QoS), IPv4 support
- IEEE 802.3, IEEE 802.3u, UPnP
- Power
- AC 120/230 V (50 - 60 Hz)
- 27.9 cm x 24.1 cm x 4.45 cm
- 1.5 kg
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, AES, SHA-1
- Authentication Method
- RADIUS
- IEEE 802.3, IEEE 802.3u, UPnP, FCC Class B certified
- Status Indicators
- System, WAN, LAN, DMZ, DMZ/Internet, diagnostic
- LAN: 8 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x power cable
- Localisation
- United Kingdom
- OS Provided
- Linux
- Software Included
- Cisco QuickVPN Client
- 27.9 cm
- 24.1 cm
- 4.45 cm
- 1.5 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 10 - 85%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
