Serial and asynchronous High-Speed WAN Interface Cards (HWICs) provide highly flexible connections for Cisco Integrated Services Routers. These HWICs help customers enable applications such as WAN access, legacy protocol transport, console server, and dial access server. You can mix and match HWICs to tailor cost-effective solutions for common networking problems such as remote network management, external dial-modem access, low-density WAN aggregation, legacy protocol transport, and high-port-density support.
Legacy protocol transport
Serial and synchronous/asynchronous ports are ideally suited to transport legacy traffic across a TCP/IP network, facilitating network convergence and eliminating costly separate leased lines for this traffic. -
Dial access server
Asynchronous HWICs can connect to external dial modems to provide low-density dial access servers.
- Cisco High-Speed - expansion module - HWIC
- Expansion module
- Form Factor
- Plug-in module
- Interface (Bus) Type
- HWIC
- Data Link Protocol
- RS-232, RS-530, X.21, V.35, RS-449, RS-530A
- Data Transfer Rate
- 8 Mbps
- Designed For
- Cisco 1841, 1841 2-pair, 1841 3G, 1841 4-pair, 1841 ADSL2, 1841 T1, 1921 4-pair, 1921 ADSL2+, 1921 T1, 19XX, 28XX, 28XX 2-pair, 28XX 4-pair, 28XX V3PN, 29XX, 38XX, 38XX V3PN, 39XX
- Expansion module
- Form Factor
- Plug-in module
- HWIC
- Connectivity Technology
- Wired
- 8 Mbps
- Status Indicators
- Port status
- 1 x RS-232/449/530/V.35/X.21
- Compatible Slots
- 1 x HWIC
- FCC Class A certified, TUV GS, CISPR 24, EN 60950, EN 61000-3-2, IEC950, UL 1950, VCCI Class A ITE, EN 61000-3-3, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, AS/NZ 3548 Class A, FCC Part 15, ICES-003 Class A
- Designed For
- Cisco 1841, 1921, 1921 ADSL2+ Bundle, 1921 T1 Bundle, 1941, 1941 Mobile Wireless, 1941 Secure WAAS Bundle, 1941 Security, 1941 WAAS Bundle, 2801, 2801 Unified Communications Bundle, 2801 Unified Communications Bundle with Advanced Security, 2811, 2811 Terminal Server Bundle, 2811 Unified Communications Bundle, 2811 Unified Communications Bundle with Advanced Security, 2811 WAN Application Acceleration Bundle, 2821, 2821 Branch Office in a Box Bundle, 2821 Secure WAN Optimization Bundle, 2821 Unified Communications Bundle, 2821 Unified Communications Bundle with Advanced Security, 2821 WAN Application Acceleration Bundle, 2821 WAN Optimization Bundle, 2851, 2851 Secure WAN Optimization Bundle, 2851 Unified Communications Bundle, 2851 Unified Communications Bundle with Advanced Security, 2851 WAN Application Acceleration Bundle, 2851 WAN Optimization Bundle, 2901, 2901 Secure WAAS Bundle, 2901 Terminal Server Bundle, 2901 Voice Security and CUBE Bundle, 2901 WAAS Bundle, 2911, 2911 Secure WAAS Bundle, 2911 UCSE Bundle, 2911 Voice Security and CUBE Bundle, 2911 WAAS Bundle, 2921, 2921 Secure WAAS Bundle, 2921 Voice Security and CUBE Bundle, 2921 WAAS Bundle, 2951, 2951 Secure WAAS Bundle, 2951 UCSE Bundle, 2951 Voice Security and CUBE Bundle, 2951 WAAS Bundle, 3825, 3825 Branch Office in a Box Bundle, 3825 Secure WAN Optimization Bundle, 3825 SRST Voice Upgrades for HSEC Bundle, 3825 Unified Communications Bundle, 3825 Unified Communications Bundle with Advanced Security, 3825 WAN Application Acceleration Bundle, 3825 WAN Optimization Bundle, 3845, 3845 Branch Office in a Box Bundle, 3845 Unified Communications Bundle with Advanced Security, 3845 WAN Application Acceleration Bundle, 3845 WAN Optimization Bundle, 3925, 3925 PSRE Bundle, 3925 Voice Security and CUBE Bundle, 3925 WAAS Bundle, 3925E, 3925E Voice Security and CUBE Bundle, 3945, 3945 PSRE Bundle, 3945 WAAS Express Bundle, 3945E
C2G 5m DB9 M/F Extension Cable - Black | In Stock | £10.52 |
