Cisco IP 6941 Refurb
Quicklinx: F4MGWS00 Mfr#: CP-6941-C-K9#REFURB
The Cisco Unified IP Phone 6941 is an innovative IP endpoint that delivers affordable, business-grade voice communication services to customers worldwide.
The Cisco Unified IP Phone 6941 supports four lines and a full-duplex speakerphone for a more productive, more flexible, and easier-to-use endpoint experience. The Cisco Unified IP Phone 6941 supports single-call per-line appearance, offering traditional telephony-like user experience for customers who seek this type of call interaction for their users. Fixed keys for hold, transfer, and conference; tri-color LED line and feature keys also make the phone simpler and easier to use.
The Cisco Unified IP Phone 6941 is also more energy-efficient and eco-friendly, in support of customer green initiatives. A deep-sleep option provides energy savings. With this option, Cisco Unified IP Phone 6941 consumes up to 50-percent less power in off-hours versus when the phone is idle during normal business hours. In addition, reground and recyclable plastics deliver a more earth-responsible solution.
  • Lighted hold key
    The key lights when pressed to put a call on hold and stays lit until the held call has been resumed, or flashes if one call is held while another is engaged; the key is dark when no calls are on hold.
  • Lighted menu key
    The key lights when pressed to access voicemail messages, call logs, network settings, user preferences, corporate directories, and XML services; it stays lit while menu items are active.
  • Lighted message waiting indicator
    The key lights when there is new voicemail, and the light is visible on both the phone chassis and the handset; it stays lit until you process your new voicemail.
  • Co-branding
    Co-branding button allows customers to include their logo on the Cisco Unified IP Phone 6900 Series phones. Cisco has approved third- party vendors to produce the buttons.
  • Graphical display
    A white backlit, monochrome, 396 x 162 pixel-based display with anti-glare screen provides scrollable access to calling features and text-based XML applications.
  • Ethernet switch
    The phone has a 10/100BASE-T Ethernet connection through two RJ-45 ports, one for the LAN connection and the other for connecting a downstream Ethernet device such as a PC.
  • Volume control
    A volume-control toggle provides easy decibel-level adjustments of the handset, monitor speaker, and ringer.
  • Dual-position foot stand
    The display is easy to view and the buttons and keys are easy to use; you can remove the foot stand for wall mounting, with mounting holes located on the base of the phone.
  • Multiple ring tones
    The phone offers seven user-adjustable ring tones.
  • American Disabilities Act (ADA) features
    The hearing-aid-compatible (HAC) handset meets the requirements set by the ADA; it also meets ADA HAC requirements for a magnetic coupling to approved hearing aids. The phone dialing pad also complies with ADA standards.
Cisco Unified IP Phone 6941 Standard - VoIP phone
VoIP phone
Main Features
Integrated Ethernet switch
VoIP Protocols
SCCP
Voice Codecs
G.729a, G.729ab, G.711u, G.711a
Lines Supported
Multiline
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Transfer, Call Hold
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Body Colour
Charcoal
1-year warranty
VoIP phone
Body Colour
Charcoal
Body Material
ABS plastic
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Conference button, transfer button, hold button
Volume Control
Ringer Control
Ring Tones
7
Indicators
Voice message waiting indicator
Firmware Upgradable
IP Telephony
Main Features
VoIP
VoIP Protocols
SCCP
Voice Codecs
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
Power Over Ethernet (PoE) Support
Network Protocols
TFTP, Cisco Discovery Protocol (CDP)
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD)
Display
Display Location
Base
Display Resolution
396 x 162 pixels
Backlit
Display Languages
Danish, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Bulgarian, Serbian, Catalan, Japanese, Chinese, Korean
Headset jack
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Power adapter
VCCI Class B ITE, CISPR 22 Class B, CISPR 24, EN 60950, EN 61000-3-2, IEC 60950, EN 61000-3-3, EN55024, UL 60950, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, ACA TS001, AS/NZS 60950-1, CSA C22.2 No. 60950-00, FCC CFR47 Part 68, FCC CFR47 Part 15 B
Power adapter - external
Dimensions & Weight (Base)
18.8 cm
20.5 cm
16.4 cm
1 kg
Limited warranty - 1 year
