Door/Window contacts can be used to raise an alarm if someone tries to leave a property at an inappropriate time. Once the door or window has been opened, this will raise a call to the monitoring centre. They will also work in conjunction with the movement sensors, so that if the `away' button is pressed on the CareUnity when the person leaves the property, the contacts will add to the basic intruder system.
