Modern design, accurate scroll wheel action and precise mouse key pressure points make this product unique in its price class. The solid rubber sides make the mouse comfortable to use and ensure smooth, accurate cursor control even in hectic situations. The GENTIX mouse can be connected quickly and easily to any Notebook, PC or Mac via the 1.8-meter cable with USB connection.
- CHERRY GENTIX - mouse - USB - grey, white
- Mouse
- Connectivity Technology
- Wired - USB
- Grey, white
- Orientation
- Right and left-handed
- 6.86 cm x 11.15 cm x 3.5 cm
- 120 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, rubber side grips
- Cable Length
- 1.8 m
- Microsoft Certification
- Compatible with Windows 7
- 2 years warranty
- Mouse
- Orientation
- 6.86 cm
- 11.15 cm
- 3.5 cm
- 120 g
- Grey, white
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Cable Length
- 1.8 m
- 1 x USB - 4 pin USB Type A
- Plug and Play, C-Tick, BSMI, FCC, VDE GS, cTUVus
- Limited warranty - 2 years
- 0 °C
- 40 °C
