Product
Cherry Gentix Optical Mouse Mac/PC Grey/White
Quicklinx: BYKBWS00 Mfr#: JM-0300-0
Wired / Wireless: Wired
Colour: Grey, White
Compatibility: Mac, PC
More than 50 in stock
£5.45 ex VAT
£6.54 inc VAT
Modern design, accurate scroll wheel action and precise mouse key pressure points make this product unique in its price class. The solid rubber sides make the mouse comfortable to use and ensure smooth, accurate cursor control even in hectic situations. The GENTIX mouse can be connected quickly and easily to any Notebook, PC or Mac via the 1.8-meter cable with USB connection.
CHERRY GENTIX - mouse - USB - grey, white
Mouse
Wired - USB
Grey, white
Orientation
Right and left-handed
6.86 cm x 11.15 cm x 3.5 cm
120 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, rubber side grips
Cable Length
1.8 m
Microsoft Certification
Compatible with Windows 7
2 years warranty
Mouse
Orientation
6.86 cm
11.15 cm
3.5 cm
120 g
Grey, white
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Cable Length
1.8 m
1 x USB - 4 pin USB Type A
Plug and Play, C-Tick, BSMI, FCC, VDE GS, cTUVus
Colour: Grey
Colour: White
Compatibility: Mac
Compatibility: PC
Brand: Cherry
Price Range Ex VAT: 0 - 50
