Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard. For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality.
Freeview
Freeview is a free digital TV service. It provides 50 digital TV channels and 24 radio stations with no need for a subscription. All Cello TVs include Freeview as standard. -
Full HD
For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality. -
USB
USB recording feature - Simply insert a USB memory stick. Highlight the program to record on the 7 day EPG and press record. You can also pause live TV. -
T2 Freeview HD
With DVB-T2 you can view your Freeview channels in full high definition. DVBT2 is the world's most advanced digital terrestrial television (DTT) system. -
4K Ultra HD
4K Ultra HD Or Ultra High Definition is the next big step In HDTV solution. It shows four times more clarity than normal full high definition.
- Cello C75238T2-4K 75" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV
- Diagonal Class
- 75"
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 120Hz Refresh Rate
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- Digital TV Tuner
- DVB-C, DVB-T, DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- 203 Watt
- Power Consumption Stand by
- 0.4 Watt
- Dimensions (WxDxH) - without stand
- 167.8 cm x 6.5 cm x 96.4 cm
- Product Type
- Energy Class
- Class A
- 203 Watt
- Diagonal Class
- 75"
- TV Tuner Presence
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 3 ports
- HDCP Compatible
- Dimensions
- Without stand
- 167.8 cm
- 6.5 cm
- 96.4 cm
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 250 cd/m²
- Comb Filter
- 3D digital
- 3D Noise Reduction, 3D De-interlace, Color Tint Control
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 400 mm
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- MPEG Profiles and Levels
- MPEG2 MP@HL
Video Features
- Analogue Video Input Signals
- PAL, SECAM
- Electronic Programme Guide
- Digital EPG, MHEG-5
Media Player
- Supported Video Formats
- MPEG-2, MPEG-4, H.264
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Digital Audio Format
- MPEG 2 digital output, MPEG 1 digital output
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- Speakers
- 2 x main channel speaker - 8 Watt
- Connector Type
- Component video input , 3 x HDMI input , Headphones , Digital audio output (coaxial) , USB 2.0 , Audio line-in
- Plug and Play
- Input Voltage
- 0.4 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 167.8 cm x 6.5 cm x 96.4 cm , Panel with stand - 167.8 cm x 26.69 cm x 101 cm
