Product
Brand
Cello C32227DVB 32" HD Ready LED TV 1366 x 768
Quicklinx: 9JZ4WS00 Mfr#: C32227DVB
  • FREEVIEW
  • DVB-T
Enjoy 720p performance anywhere on Cello's C3222DVB 32 Inch Freeview LED TV.
The HD Ready screen provides the pinnacle of picture quality with unprecedented clarity and vibrant colours - all the while ensuring that energy consumption is kept to a minimum. It's the only way to experience your Blu-ray and HD gaming.
Watch the best of British TV for absolutely FREE on the C3222DVB LED TV. Enjoy a huge selection of free digital TV and radio channels, including BBC Three and ITV 2 without the need for an extra set top box.
Cello's C3222DVB LED TV boasts an extensive range of connectivity options for you to maximise you viewing experience; the HDMI ports allows for easy connection to your games console or other HD devices, while the PC input lets you to connect your PC and use the TV as a PC monitor.
The USB port enables you to connect a digital camera or MP3 player to the TV and playback your photos and stored music directly on the TV screen. You can also use a USB device to record and catch up on TV programmes you may have missed.
Cello C32227DVB 32" LED TV
LED-backlit LCD TV
Diagonal Class
32"
Resolution
1366 x 768
Display Format
720p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Digital TV Tuner
DVB-T, QAM
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
USB
Voltage
AC 120/230 V
Energy Class
Class A
Power Consumption (On mode)
35 W
Energy Consumption per Year
52 kWh
73.8 cm x 9.2 cm x 44 cm
LED-backlit LCD TV
Energy Class
Class A
35 W
52 kWh
Diagonal Class
32"
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
73.8 cm
9.2 cm
44 cm
Display
Resolution
1366 x 768
Display Format
720p
LED backlight
Image Contrast Ratio
3000:1
Brightness
250 cd/m²
Comb Filter
3D digital
3D Noise Reduction, 3D De-interlace
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T, QAM
Digital TV Service
FREEVIEW, SAORVIEW
MPEG Profiles and Levels
MPEG2 MP@HL
Video Features
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
1
Audio System
Speaker System
2 speakers
Output Power / Total
16 Watt
Speakers
2 x main channel speaker - built-in - 8 Watt
Connector Type
3 x HDMI input , Component video input , VGA input , Audio line-in , SCART , Composite video/audio input , Digital audio output (coaxial) , Headphones , USB 2.0
Plug and Play
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 73.8 cm x 9.2 cm x 44 cm , Panel with stand - 73.8 cm x 20.4 cm x 49 cm x 6 kg
