Product
Cello C28227F 28" HD Ready LED TV Built-In DVD Player
Quicklinx: 9JYWWS00 Mfr#: C28227F
  • FREEVIEW
  • DVB-T
With this TV you can connect three external devices using the three available HDMI connections. The Digital TV technology brings you digital broadcast signals and an Electronic Program Guide (EPG) allowing you to view TV listings up to 7 days in advance. You can also playback music, films and photos using the USB port.
  • DVD
    Integrating a DVD player into the TV is a great way to combine two units into one neat package. As well as saving space it means less cables and one remote control.
  • HDMI
    HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray disc players.
  • USB
    Simply insert a USB memory stick. Highlight the program to record on the 7 day EPG and press record. You can also pause live TV.
Cello C28227F 28" LED TV
LED-backlit LCD TV with built-in DVD player
Diagonal Class
28"
Resolution
1366 x 768
Display Format
720p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
Digital TV Tuner
DVB-T
Analogue TV Tuner
PAL, SECAM
Speaker System
2 speakers
Stereo Reception System
NICAM, A2
DVD
DVD player
USB
Remote Control
Standard remote
Voltage
AC 120/230 V
Energy Class
Class A
35 Watt
Energy Consumption per Year
40 kWh
64.5 cm x 20 cm x 45.2 cm
5 kg
LED-backlit LCD TV
Energy Class
Class A
35 Watt
40 kWh
Diagonal Class
28"
Combined with
Built-in DVD player
Extended PVR
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Timer Functions
Sleep, record
Dimensions
With stand
64.5 cm
20 cm
45.2 cm
5 kg
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
3000:1
Brightness
220 cd/m²
Widescreen Modes
Conventional 4:3, Full, Zoom, 16:9
Comb Filter
3D digital
Colour Temperature Control
Yes (Standard/Cool/Warm)
3D Noise Reduction, time-shift, 3D De-interlace
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Flat Panel Mount Interface
100 x 200 mm
DVD
DVD player
TV Tuner
Analogue TV Tuner
PAL, SECAM
Conditional Access
Common Interface (CI) slot
Reception System
SECAM-D, SECAM-B, SECAM-K, PAL-B, SECAM-G, PAL-G, PAL-I, PAL-D, SECAM-L, PAL-K
NICAM, A2
Digital TV Tuner
Digital TV Tuner
DVB-T
Digital TV Service
FREEVIEW, SAORVIEW
MPEG Profiles and Levels
MPEG2 MP@HL, MPEG2 MP@ML
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA)
Teletext
Electronic Programme Guide
Digital EPG
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, WMV, AVI, H.264
Supported Audio Formats
MP3, WMA, WAV, AC3, AAC
Supported Pictures Formats
BMP, JPG, GIF, TIFF, PNG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Audio Controls
Sound mode, balance, bass, treble
Speaker System
2 speakers
Output Power / Total
10 Watt
Speakers
2 x main channel speaker - built-in - 5 Watt
Connector Type
VGA input - side , Composite video/audio input - side , Component video input - side , 3 x HDMI input - bottom , Headphones - side , Digital audio output (coaxial) - side , USB 2.0 - side , Audio line-in - side , SCART - bottom
EN55022, EN55013, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EN 55020:2007, EN 55024-2:1998+A1:2001+A2:2003
Power adapter
Nominal Voltage
AC 120/230 V
Power Consumption Stand by
0.4 Watt
Dimensions & Weight Details
Panel with stand - 64.5 cm x 20 cm x 45.2 cm x 5 kg , Panel without stand - 64.5 cm x 7.4 cm x 40.3 cm
35 °C
