This slimline 1080p Full HD TV is and asset for any living area.
Watch your Freeview programmes on the 1920 x 1080 resolution screen.
Connect your external devices to the 3 x HDMI ports, you can also record TV, play music and video files or show photos and text files by connecting a USB Device to the USB port on the TV.
The Electronic Programme Guide (EPG) allows you to view TV listings up to 7 days in advance also with reminder and timer record options.
Watch and enjoy your favorite films on the High grade intergrated DVD player.
The SRS TruSurround option will enhance your audio experience.
DVD
Integrating a DVD player into the TV is a great way to combine two units into one neat package. As well as saving space it means less cables and one remote control. -
Full HD
For the ultimate high definition experience, Cello Full HD TV delivers 1080 horizontal lines per frame, bringing you the ultimate in TV viewing picture quality. -
USB
USB recording feature - simply insert a USB memory stick. You can also pause live TV. -
HDMI
HDMI connections provide superior, uncompressed digital video and audio quality. Ideal for connecting your TV to devices such as satellite boxes and Blu-ray Disc players.
- Cello C40227FT2 40" LED TV
- Product Type
- LED-backlit LCD TV with built-in DVD player
- Diagonal Class
- 40"
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- LED backlight
- Digital TV Tuner
- DVB-T2
- Analogue TV Tuner
- PAL, SECAM
- Speaker System
- 2 speakers
- Stereo Reception System
- NICAM, A2
- DVD
- DVD player
- USB
- Remote Control
- Standard remote
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A
- Power Consumption (On mode)
- 62 W
- Energy Consumption per Year
- 91 kWh
- Dimensions (WxDxH) - without stand
- 93.2 cm x 8.8 cm x 56.1 cm
- 9.6 kg
- Product Type
- Energy Class
- Class A
- 62 W
- 91 kWh
- Diagonal Class
- 40"
- Combined with
- Built-in DVD player
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- VGA (HD-15)
- Dimensions
- Without stand
- 93.2 cm
- 8.8 cm
- 56.1 cm
- 9.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (Full HD)
- LED backlight
- Image Contrast Ratio
- 3000:1
- Brightness
- 230 cd/m²
- Comb Filter
- 3D digital
- 3D Noise Reduction, 3D De-interlace
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm
DVD
- DVD player
TV Tuner
- Analogue TV Tuner
- PAL, SECAM
- Conditional Access
- Common Interface (CI) slot
- NICAM, A2
Digital TV Tuner
- Digital TV Tuner
- DVB-T2
- Digital TV Service
- FREEVIEW, SAORVIEW
- MPEG Profiles and Levels
- MPEG2 MP@HL, MPEG4 AVC/H.264
Video Features
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Standard remote
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 16 Watt
- SRS TruSurround HD
- Speakers
- 2 x main channel speaker - built-in - 8 Watt
- Connector Type
- 3 x HDMI input , VGA input , SCART , USB 2.0 , Composite video input , Component video input , Audio line-in , Digital audio output (coaxial) , Headphones
- Plug and Play
- Power Device
- Power supply
- Nominal Voltage
- Power Consumption Stand by
- 0.5 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 93.2 cm x 8.8 cm x 56.1 cm x 9.6 kg , Panel with stand - 93.2 cm x 23 cm x 60.1 cm
- 0 °C
- 40 °C
