With TCO substantially reduced by their long-life light source, low energy consumption and filter-free design, CASIO Lamp Free projectors afford a wide range of value for use in everything from business to education.
Light control
Brightness is automatically adjusted to the optimal level for room brightness, which reduces electrical power costs. Adjustment is one of 7 brightness levels and Manual adjustment is also supported. -
Freely configurable projection orientation
There is a wide variety of projection setup to meet various uses, however almost mainstream projectors are capable of only two orientations, Desktop and Ceiling mounted. XJ-V110W realized more configuration freedom, and it supports a wide range of applications. -
Stylish compact design
The structure with its square form and flowing curves exemplifies contemporary design excellence. The compact projector body assures easy portability for every user.
- Casio Core XJ-V110W - DLP projector - white
- DLP projector
- White
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, component video
- 165 Watt
- 29.9 cm x 29.9 cm x 9.7 cm
- 3.5 kg
- DLP projector
- Enclosure Colour
- White
Projector
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 89 cm - 762 cm
- Throw Ratio
- 1.32 - 1.93:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Intelligent Brightness Control, instant on/off
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 5 pin Micro-USB Type B
- Included Accessories
- 2 x AAA batteries, remote control
- Cables Included
- 1 x VGA cable
- 165 Watt
- Power Consumption Stand by
- 0.23 Watt
- 29.9 cm
- 29.9 cm
- 9.7 cm
- 3.5 kg
