Casio XJ-H1700-UJ XGA DLP LED 4000 Lumens Projector
Quicklinx: 9BGVWS00 Mfr#: XJ-H1700-UJ
This model in the Pro series is perfect for large meeting rooms and school halls. Intelligent Brightness Control adjusts the light output according to the levels of ambient light, which minimizes power consumption - and running costs - by ensuring that the brightness delivered is no more than actually required.
Casio Pro XJ-H1700-UJ - DLP projector - 3D - white
DLP projector
3D Capable
White
Built-in Devices
Speaker
Brightness
4000 ANSI lumens
Contrast Ratio
1400:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, composite video
Video Modes
480p, 1080p
Speakers
Speaker(s) - integrated
350 Watt
40 cm x 32.3 cm x 10.6 cm
7.1 kg
5-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Enclosure Colour
White
Projector
Brightness
4000 ANSI lumens
Contrast Ratio
1400:1
Image Size
69 cm - 762 cm
Throw Ratio
1.6 - 1.91:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
DLP 3D Ready
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
480p, 1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
Carrying case, wireless remote control
1 x VGA cable
350 Watt
Power Consumption Stand by
0.4 Watt
40 cm
32.3 cm
10.6 cm
7.1 kg
Limited warranty - 5 years
Sound Emission
33 dB
28 dB
