Casio XJ-F210WN-UJ 3000 LM WXGA DLP Technology Projector
Quicklinx: C4DZWS00 Mfr#: XJ-A257-UJ
Portability: Portable
£1,001.22 ex VAT
£1,201.46 inc VAT
The Green Slim series is the perfect choice for customers looking to upgrade their existing installed projectors. An industry-leading 2x optical zoom means that a Green Slim model will replace any installed projector seamlessly, without having to change the ceiling brackets. This will help to keep budgets under control and disruption to a minimum. The Green Slim series offers brightness levels up to 3000 ANSI lumens more than enough for even a large, bright classroom or meeting room - and WXGA resolution. The Green Slim series has HDMI connectivity, allowing users to present HD content for rich and vivid presentations. They are also light and portable, so that they can be moved easily between rooms.
Casio Green Slim XJ-A257-UJ - DLP projector - portable
DLP projector - 720p
White
Built-in Devices
Speaker
Brightness
3000 ANSI lumens
Contrast Ratio
1800:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, composite video
Video Modes
480p, 1080p
Speakers
Speaker(s) - integrated
165 Watt
29.7 cm x 21 cm x 4.3 cm
2.3 kg
5 years warranty
Built-in Devices
Speaker
Enclosure Colour
White
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
1800:1
Image Size
38.1 cm - 762 cm
Throw Ratio
1.15 - 2.3:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Built-in 2 GB flash memory, Mercury-free illumination technology, Quick-Start
Lens
Focus Type
Powered
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
480p, 1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x USB - 4 pin USB Type A , 2 x USB - 5 pin Micro-USB Type B
Carrying case, wireless remote control
1 x VGA cable
Power Source
AC
165 Watt
Power Consumption Stand by
0.23 Watt
29.7 cm
21 cm
4.3 cm
2.3 kg
Limited warranty - 5 years
Brand: Casio
Price Range Ex VAT: 1000 - 1500
