This laser and LED hybrid projector is able to function without the use of toxic mercury and reduces the power consumption. Thanks to the use of mercury-free lighting technology, this projector is able to function for an extensive period of time without replacing the lamp.
Incredible light source
This laser and LED hybrid projector is able to function without the use of toxic mercury and reduce power consumption. -
A durable light source
Thanks to the use of mercury-free lighting technology, this projector is able to function for an extensive period of time without replacing the lamp. -
Outstanding color rendition
The amazing laser and LED hybrid light source guarantees clear and brilliant color reproduction - even in daylight. -
Flexibility through brightness control
This projector is able to adapt flexibly to different lighting conditions thanks to the dynamic brightness control. -
Kind to the environment
The light source fitted in this projector is mercury-free and environmentally friendly. -
Wireless presentations
Thanks to WLAN capabilities, this projector eliminates cumbersome wiring between the PC and projector -
Connection via HDMI
Thanks to the existing HDMI interface, the projectors can be easily connected to external components, such as a suitably equipped laptop.
- Casio Advanced XJ-F20XN-UJ - DLP projector - white
- DLP projector
- White
- Built-in Devices
- Speaker
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, S-Video, composite video, component video
- Speakers
- Speaker(s) - integrated
- 170 Watt
- 29.9 cm x 29.9 cm x 9.7 cm
- 3.5 kg
- DLP projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- White
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 76 cm - 762 cm
- Throw Ratio
- 1.66 - 2.42:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Crestron Connected
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- HDMI, component video, composite video, S-Video, RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A , 1 x network - RJ-45 (management) , 1 x microphone input - mini-phone mono 3.5 mm
- Included Accessories
- 2 x AAA batteries, remote control
- Cables Included
- 1 x VGA cable
- 170 Watt
- Power Consumption Stand by
- 0.23 Watt
- 29.9 cm
- 29.9 cm
- 9.7 cm
- 3.5 kg
- Limited warranty - lamp - 5 years / 10000 hours
- Sound Emission
- 35 dB
