The innovative light source from CASIO not only offers exceptional projection performance - due to its low wear, it also manages to deliver this continuously high level of performance over a long period of time and even makes projections possible in daylight.
CASIO projectors and their exceptional light source are sure to amaze with their brilliant color reproduction and wide color range. This optical phenomenon causes the subjective perception of brightness to increase with the degree of color saturation. As a matter of fact, the CASIO projectors cover a larger part of the color spectrum visible to the human eye. Clear, vivid images with rich colors and the finest of nuances - an immersive experience for all involved. Thanks to the direct on/off function, CASIO projectors reach their full brightness after a maximum of five seconds - at just the push of a button. As a result, long waiting times and annoying warm-up and cool-down phases are a thing of the past - a fact that saves precious time. Lessons can start immediately and follow a more flexible structure, as the projector can be switched on quickly at any time.
A durable light source
The actual power of the CASIO projectors lies deep within - the revolutionary laser and LED hybrid light source. This technology is the centerpiece of the projectors and functions without any need for quicksilver - in complete contrast to conventional projector lamps. The innovative light source from CASIO not only offers exceptional projection performance - due to its low wear, it also manages to deliver this continuously high level of performance over a long period of time and even makes projections possible in daylight. -
Outstanding color rendition
CASIO projectors and their exceptional light source are sure to amaze with their brilliant color reproduction and wide color range. This optical phenomenon causes the subjective perception of brightness to increase with the degree of color saturation. As a matter of fact, the CASIO projectors cover a larger part of the color spectrum visible to the human eye. Clear, vivid images with rich colors and the finest of nuances - an immersive experience for all involved. -
Ready to start at the push of a button
Thanks to the direct on/off function, CASIO projectors reach their full brightness after a maximum of five seconds - at just the push of a button. As a result, long waiting times and annoying warm-up and cool-down phases are a thing of the past - a fact that saves precious time. Lessons can start immediately and follow a more flexible structure, as the projector can be switched on quickly at any time. Set-up and clear-up times for business presentations are also made considerably shorter.
- Casio Advanced XJ-F10X - DLP projector - white
- DLP projector
- White
- Built-in Devices
- Speaker
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, S-Video, composite video, component video
- Video Modes
- 480p, 1080p
- Speakers
- Speaker(s) - integrated
- 170 Watt
- 29.9 cm x 29.9 cm x 9.7 cm
- 3.5 kg
- DLP projector
- Built-in Devices
- Speaker
- Enclosure Colour
- White
Projector
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.93 m
- Throw Ratio
- 1.66 - 2.42:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- Freeze frame, Direct Power On, Direct Power Off, Crestron e-Control, Intelligent Brightness Control, rear projection, instant on/off
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- HDMI, component video, composite video, RGB
- Video Modes
- 480p, 1080p
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 2 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x composite video input - RCA , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A
- Included Accessories
- 2 x AAA batteries, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Password protection
- 170 Watt
- Power Consumption Stand by
- 0.23 Watt
- 29.9 cm
- 29.9 cm
- 9.7 cm
- 3.5 kg
- 5 °C
- 35 °C
- Sound Emission
- 35 dB
