- Casio Core XJ-V1 - DLP projector - portable - white
- DLP projector - 720p
- White
- Brightness
- 2700 lumens
- Contrast Ratio
- 20000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- Laser/LED
- Bulb life cycle
- Up to 20000 hour(s)
- Video Input
- RGB, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- 150 Watt
- 27 cm x 27 cm x 8.9 cm
- 2.8 kg
- 3-year warranty
- Enclosure Colour
- White
Projector
- Brightness
- 2700 lumens
- Contrast Ratio
- 20000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.83 m
- Throw Ratio
- 1.54 - 1.71:1
- Uniformity
- 72 %
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Display Format
- 786,432 pixels
- Colour Support
- Bulb type
- Laser/LED
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- BrilliantColor, Image Freeze Function, Direct Power On, Direct Power Off, blank screen, Mercury-free illumination technology, Presentation Timer, rear projection
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI
- Video Modes
- 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 5 pin Micro-USB Type B
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection
- 150 Watt
- Power Consumption Stand by
- 0.23 Watt
- 27 cm
- 27 cm
- 8.9 cm
- 2.8 kg
- Limited warranty - 3 years - used for less than 12 hours per day , Limited warranty - lamp - 5 years / 10000 hours - used for less than 12 hours per day , Limited warranty - 2 years - used continuously (24 hours per day) , Limited warranty - lamp - 2 years / 6000 hours - used continuously (24 hours per day)
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
