Your basket is empty
Caretech Telecare Mbox Door Alarm/Property Exit Sensor
Quicklinx: 92C4WS00 Mfr#: 300146
£69.53 ex VAT
£83.43 inc VAT
Pro5 Consortium Telecare Homepage
< Click here to return to Pro5 homepage
The mBox door alarm is very easy to install and is completely wireless. A small magnet is attached to the door, and the transmitter itself is attached to the door frame. A built-in timer makes it possible to set the alarm for automatic operation at certain times. The mBox Door Alarm alerts carers if an individual with dementia leaves the accommodation, while authorised staff can simply press the bypass button to pass without activating the alarm. Please note this device is compatible with CareTech systems only.
Important note: This sensor is only compatible with CareTech Carephones.
